E4 OH NO
Old Oct 19, 2021 | 05:44 AM
Nucklehead1911's Avatar
Nucklehead1911
8th Gear
E4 OH NO
I have a 1996 f350 drw 7.3l 4x4 automatic with 130k. While cold and at lower RPMs the transmission shifts soft but as should once fluid is hot or under hard acceleration it wants to slip in 2nd and 3rd especially. Dropped the pan and changes filter and fluid also added inline filter in the hose to try and correct it with slight but almost unnoticeable change. Thinking it could be bad torque converter or transmission oil pump. What do yall think?
Old Oct 19, 2021 | 06:26 AM
FinnishStroker's Avatar
FinnishStroker
Pull codes first,with ForScan for example.
Generic readers will not work with these engines/trannys.
Old Oct 20, 2021 | 02:21 PM
Nucklehead1911
8th Gear
if there aren't any codes then what?
also no flashing on the overdrive light not sure if that matters
ryito1122334455
Jul 3, 2011 05:41 PM
fordguy55
Oct 19, 2010 05:30 PM
johnnyp302003
Sep 18, 2010 04:45 PM
ford7379trucks
Jul 16, 2009 08:32 PM
ScottR
Jun 28, 2001 03:54 PM
