E40d no forward gears
Old Oct 18, 2021 | 09:46 PM
Zachjg98's Avatar
Zachjg98
Have a 97 f350 7.3 4x4 with e40d truck had no forward gears only reverse when I got it had it rebuild have stage one shift kit and a billet torque converter running fine 3 years now I have no forward gears again but if I manually shift to first it will slowly move if I get the rpms way up reverse works fine. Trying to get ideas before I yank the whole trans out again. Been acting weird for a bit in morning would neutral drop then be fine again but not not forward at all.
trans has been shifting erratic for a bit now thought it was cause my PCM was messed up but replaced it
Old Oct 19, 2021 | 06:43 AM
FinnishStroker's Avatar
FinnishStroker
Pull codes first,with ForScan for example.
Generic readers will not work with these engines/trannys.
95rustbelt250
13
Jun 21, 2021 08:16 PM
merccougar93
Aug 20, 2010 10:42 AM
84yotaman
Jul 18, 2010 08:56 PM
torquey89ford
Feb 21, 2003 09:45 PM
