96 f150 diff.
Old Oct 18, 2021 | 08:44 PM
rdminks's Avatar
rdminks
96 f150 diff.
All I know about a rear differential is how to change oil and seals.
My 2wd door sticker says axle-reg and ratio 3.55. What is a 1996 regular axle? I want to go with a 3.73 positraction. What would be recommended for a mildly modified (320 hp or so) 5L with a 4r70w trans? Thank you in advance.
Old Oct 18, 2021 | 08:56 PM
Conanski's Avatar
Conanski
It's an 8.8 open.
4.10 gears and a Detroit Truetrac.
Old Oct 19, 2021 | 06:47 AM
My4Fordtrucks's Avatar
My4Fordtrucks
Going from 3.55 to 3.73 isn’t enough of a difference to make it worth the trouble. What size tire?
Old Oct 19, 2021 | 08:04 AM
Hit Man X's Avatar
Hit Man X
I went from a 3.55:1 to 4.10:1 in my '88. You actually notice it, going to a 3.73:1 is a waste of time. Mine has an old Eaton LSD as the Truetrac was not available nearly 20 years ago. Works fine, just dated tech.
TT is a great unit and would also recommend. I had one in my 6.4 and performed flawlessly.
I would do a higher stall converter first, unless you already have done so.
Old Oct 20, 2021 | 05:53 PM
rdminks's Avatar
rdminks
Thanks for the help. I've never driven anything with gearing as low as 4:10 except possibly a John Deere tractor. I thought it might be too much. My tires are 275/45/R20's all the way around but they're only 1-1.5 inches taller than the original 15 inch. I suppose if I only get 12 mpg what the heck will another minus 2 or 3 matter with 4:10. Have to think about what to tell my grand kids about burning up their precious fossil fuels though. Elon Musk has their backs sounds pretty good.
Old Oct 20, 2021 | 05:57 PM
Hit Man X's Avatar
Hit Man X
How heavy are those wheels? You may gain economy dumping that unsprung weight.
Finally scored DRW Alcoas for my 96. Steelies are around 43lb/ea. The aluminum ones are 20. Yah. HUGE drop. Econ will go up, acceleration will be quicker, etc.
Old Oct 20, 2021 | 06:28 PM
rdminks's Avatar
rdminks
I would say the weight is about the same, steel vs Chrome alloy. To absolutely convince you all I know nothing about machine rear ends, to go to a trutrac, do I put the unit in my current diff. housing with stock axles? The only info on my door sticker is 3.55 reg.
Old Oct 20, 2021 | 06:36 PM
rdminks's Avatar
rdminks
Old Oct 20, 2021 | 10:51 PM
Hit Man X's Avatar
Hit Man X
Yes, you would reuse the axle housing and axles. Other parts are swapped. Just the carrier is pretty easy, first time is involved for a regear.
I like FMS gears, my pal with an offroad shop loves Yukon. I would use either. Often you reuse the OE pinion shim upon initial setup for your baseline. Worst part is setting pinion depth and its rotational torque on it. Many are getting away from the crush sleeve, read into the advantages and disadvantages.
Surely there are guys here that do more 8.8s than I that can offer you many tips. I do many more drop outs on Euro cars.
Most toolz required are modest in cost and will last a lifetime if kept safe, like any precision tool. Hell, you may have a few of these already!
1Austin112
Jan 3, 2016 03:44 PM
eduhat
Dec 22, 2015 06:29 PM
blownstude
Aug 31, 2006 06:45 PM
95frd
Oct 20, 2003 01:29 AM
redtopper
Apr 10, 2002 01:41 PM
