Running Board Lighting Circuit Help
Old Oct 18, 2021 | 02:39 PM
kevinr7290's Avatar
kevinr7290
I have a 2020 F250 Platinum that has a plug on either side behind the running boards attached to the frame. I have seen videos of people buying the adapter and plugging them in at these locations and they work fine. I plugged in on the passenger side and it worked great. Plugged in a drivers side and no power. Checked with volt meter no power when door is open on the drivers side.
Any idea why it may not be working? Anyone have the wiring diagram for these plugs or know what fuse may be associated with the drivers side plug?
Thanks for the help.
Kevin
2020 F250 Platinum 6.7L
Old Oct 19, 2021 | 08:55 AM
Ding126's Avatar
Ding126
Those plugs are for running board lights and will energized with key fob like the puddle lights , park & bed lights etc
Old Oct 19, 2021 | 09:12 AM
kevinr7290's Avatar
kevinr7290
Originally Posted by Ding126
Those plugs are for running board lights and will energized with key fob like the puddle lights etc
I agree with what you are saying, but the passenger one does have power when you open the door and the drivers side does not for some reason?
Old Oct 19, 2021 | 09:27 AM
Ding126's Avatar
Ding126
how are you testing that specific connector? Also I had a company, Boosted gray goose make me a connector for each side. The connectors are different starting in 2020 i believe. or tap directly to wires.
I would double check to confirm no voltage to drivers side.. probe / wires crossed?
Old Oct 19, 2021 | 09:39 AM
kevinr7290's Avatar
kevinr7290
I used the plug recommended by most. I plugged in on the passenger side and it worked fine. Removed and moved to drivers side just to be sure and nothing. I plugged in the connector and using by meter checked the pigtails from the connector and nothing with the door opening and boards going down.
Boosted gray goose? what did the connector look like? Do you have a link? I will double check the factor connector again when I get home just to be sure. Seems like somehow that side is not getting power for some reason.
Old Oct 19, 2021 | 10:57 AM
Ding126's Avatar
Ding126
https://www.boostedgreygoosedesigns....Steering+Wheel
Old Oct 19, 2021 | 11:48 AM
Norcalpr's Avatar
Norcalpr
Why does he need to buy a connector he already has? Did you read his post at all? Good God this forum is so unhelpful sometimes...
It should get power if either door opens. Should be triggered by the ecu. Have you thrown a meter on it? Troubleshooting without a meter is troubleshooting blindly.
I'll try and dig up a diagram?
Old Oct 19, 2021 | 11:52 AM
kevinr7290's Avatar
kevinr7290
I did it had zero volts or micro voltage on the line when I checked before where the passenger side reads 12+ volts. So I know something is not connected anymore or maybe never was. I figured if I had the wiring diagram I could check all of the plugs to see and troubleshoot from there.
Old Oct 19, 2021 | 12:50 PM
2020STX250's Avatar
2020STX250
Just curious if the pin on the truck side connector is fully seated in the factory connector. Might have backed out a bit and isn't making contact with your pigtail.
Old Oct 19, 2021 | 01:05 PM
BigUnixGeek's Avatar
BigUnixGeek
Fuse blown? Installed, even?
Old Oct 19, 2021 | 01:20 PM
cayenne's Avatar
cayenne
Good God man - did you happen to read either? He said he checked it with a multi-meter
Old Oct 19, 2021 | 03:14 PM
ClintW's Avatar
ClintW
Why did Ford remove the plug on the newer model 250's?!? I have 22 F250 Lariat Tremor and these quick access plugs do not exist. I did find a YT video that says to search under the door sill wire bundle for a gray / violet trace for (+) and black w/ yellow trace for (-)....I found what I thought to be the gray / violet but when you hook up a multimeter there's 12v dc regardless of the map lights being on or off....Wondering what new build folks are doing here.
Old Oct 19, 2021 | 04:33 PM
kevinr7290's Avatar
kevinr7290
That's what I asked in my original post for wiring diagram or if anyone knew for certain which fuse it may be for the driver side?
Old Oct 19, 2021 | 08:41 PM
Ding126's Avatar
Ding126
deleted .....
Old Oct 19, 2021 | 08:44 PM
Ding126's Avatar
Ding126
The connector on the right is the correct one needed for your lights...the one on the left is what everyone SAYS you need. right?
You can take the plug out and make a connector if you have the correct pins...it was easier to have BGG make two pig tails IMO
