Shocks
Old Oct 17, 2021 | 05:26 PM
stvneil's Avatar
stvneil
Shocks
2016 SC F-150 FX4, any recommendations on replacement shocks? Don't off road anymore and looking for a smoother ride.
Old Oct 17, 2021 | 06:27 PM
JKBrad's Avatar
JKBrad
Rancho 9000 adjustable shocks. You can set the. To ride form or soft. Most like firm and Bilstein is the recommendation there.
Old Oct 17, 2021 | 08:37 PM
Beechkid's Avatar
Beechkid
with regards to shocks.....IMHO:
1) Koni- Excellent for racing applications- overpriced for street applications
2) Tokico, QA1 & Bilstein- A very good shock for street/strip applications- but. QA1 & Bilstein have periodic/intermittent QA issues. If you are running very stiff tires on the street (such as Bridgstone or tires with profiles shorter than 50 series), these provide the extra give that you need for both comfort & stability
3) KYB- A very good shock for street/strip applications. If you are running a softer tires on the street (such as BFG or tires with profiles not shorter than 50 series), these provide the extra stiffness that you need for both comfort & stability. The Exel-G’s (formerly GR-2) are the equivalent to the Edelbrock IAS automatic adjusting units. Overall, stiffness between the Gas-a-just and the GR2’s are the same, the difference is the GR-2's valving which stiffens things up from a oem setting to that of the Gas-a-just units. I have personally run these on everything for about 30 years.
4) Gabriel- A very nice good quality HD OEM replacement type unit.
5) Monroe- stay away from that junk!
Rancho.... I have no experience with them nor do I hang out with the crowds that use them.....
Old Oct 17, 2021 | 09:13 PM
JKBrad's Avatar
JKBrad
The best replacement shocks I’ve used are several sets of KYBs, which are quite firm and why I didn’t recommend them. And Rancho 5000s. The Rancho 5000s made my ‘97 F250 ride a whole lot better than the OEM shocks did.
Old Oct 18, 2021 | 07:38 AM
ingman's Avatar
ingman
Beechkid, great info, thanks. I'll be fallowing this thread.
Old Oct 18, 2021 | 11:13 AM
jake415's Avatar
jake415
Quote:
2) Tokico, QA1 & Bilstein- A very good shock for street/strip applications- but. QA1 & Bilstein have periodic/intermittent QA issues. If you are running very stiff tires on the street (such as Bridgstone or tires with profiles shorter than 50 series), these provide the extra give that you need for both comfort & stability.
I agree 100% with this statement. I have the lower profile OEM "sport truck" tires with Bilsteins and I am very happy with the upgrade. Will never go back to stock shocks....
Old Oct 18, 2021 | 12:10 PM
GlueGuy's Avatar
GlueGuy
Of course, you always go back to stock shocks whenever you get a new truck.
That said, this is great information, and useful to me because I am at that new shock stage with our 2015.
Old Oct 18, 2021 | 02:34 PM
stvneil's Avatar
stvneil
Thanks everyone, going SHOCK shopping
Old Oct 18, 2021 | 03:55 PM
GABAR's Avatar
GABAR
Take a look at the yellow Bilstein or the black Eibach.
Old Oct 18, 2021 | 04:39 PM
KJ Smith's Avatar
KJ Smith
I'm a (yellow) Bilstein fan.
Old Oct 29, 2021 | 11:02 AM
Zzoogg's Avatar
Zzoogg
I tried Bilstein rear shocks on my 2020 F-150. I found them extremely hard and stiff though they did improve the handling a lot.
I swapped them for the Rancho 9000 adjustable shocks and I’m very happy with them. I have them on setting #2 and it helps the handling but not real stiff….much better than Bilstein. Of course I can set them to a higher setting if I opt to haul a bunch.
mericanwit
2004 - 2008 F150
13
Sep 21, 2018 10:40 AM
CaptainFoMoCo
Jan 5, 2018 04:50 PM
ggwash21
2004 - 2008 F150
17
Nov 14, 2008 07:54 PM
wendell borror
Offroad & 4x4
Apr 7, 2006 09:48 AM
rustynuts
1983 - 2012 Ranger & B-Series
Jan 16, 2003 08:02 AM
