I6 to 302 Question
Old Oct 16, 2021 | 10:15 PM
68FordTruck's Avatar
68FordTruck
I6 to 302 Question
I am thinking about taking out my inline 6 cylinder (out of my 1975 F100) and putting in a 302 out of an 89 Ford. I know that I will need to change the motor mounts, but will I need to change the frame mounts that the motor mounts fit into?
Old Oct 16, 2021 | 10:45 PM
ranger140892's Avatar
ranger140892
Grumpy goat
Normally you'd could go to Bronco Graveyard website and see if the frame towers are different between 300 and 302, but their site is down. I do know you transmission's bellhousing is the same as a Windsor's.
Old Oct 17, 2021 | 01:02 AM
85e150's Avatar
85e150
Something wrong with the 300? What condition is the 302?
Not all 302s are created equal and that '89 if OEM and half worn out might not have any more beans than a good running 300.
Check twice, swap once.
Swerving suggestion
Old Oct 17, 2021 | 08:07 AM
68FordTruck
The 300 runs great, it just has very low oil pressure. I am going to take the oil pan off to see if the oil pump is stopped up. The engine doesn't smoke or have any knocks. I am just getting a plan together incase I can't get the oil pressure up. I have a 302 that has been rebuilt.
Old Oct 17, 2021 | 10:54 AM
jackietreehorn's Avatar
jackietreehorn
302 should bolt up except for mounts. A 89 302 is a turd anyway and hardly better than the six.
If you are going through all this, you would be better off with a 95-97 351w, bolts exactly the same as the 302 but has more torque, HP, and longevity due to roller cam and lifters.
My vote would be replace with HV oil pump, and ensure PCV is functional. Use 15w-40 or 20w-50 oil should get you many more years or miles.
Old Oct 17, 2021 | 11:03 AM
Its_Green's Avatar
Its_Green
Oil pressure is optional in a 300.
Old Oct 17, 2021 | 09:57 PM
jswartz84's Avatar
jswartz84
This is the motor mount kit I used.
https://www.summitracing.com/parts/trd-4562
Old Oct 18, 2021 | 12:37 PM
5851a's Avatar
5851a
My Dads with a 240 had low pressure, he bought it used and abused but looked good. I pulled engine, put in new bearings and seals. Never pulled the head just new valve seals. It was on the road for another 20 years with good pressure.
Old Jan 31, 2022 | 06:23 PM
John89's Avatar
John89
Hey jswartz84, do you have any pictures of your 302 on the trans dapt mounts you could post? Do you just remove the stock towers and bolt in the kit?
Our 300 has a rod knock and are talking through our options.
TIA.
Old Feb 1, 2022 | 06:42 AM
Meridian_Mike's Avatar
Meridian_Mike
You do have to change the frame "towers" where the motor mounts bolt to the frame.
There is a BIG difference between the I6 towers and the 302 V8 towers. Both sets will bolt to holes already in the frame.
Look at post #5 in my build thread...... It shows the I6 sitting in my frame.
Then, scroll down and look at post #46... That is my 302 V8 bolted in.
https://www.ford-trucks.com/forums/1...storation.html
Good luck.
estrozyk
20
Jan 12, 2023 03:50 PM
sandhillmike
Sep 6, 2006 06:12 PM
nomadshirt
Feb 12, 2006 05:21 AM
custom68
Feb 27, 2004 10:55 AM
paulmello
Apr 29, 2003 05:08 PM
