Sponsored by: Auxito
2008 ford taurus x sel suv p1260 code
Old Oct 15, 2021 | 12:10 AM
snetto87's Avatar
snetto87
Question 2008 ford taurus x sel suv p1260 code
Spoiler
Old Oct 15, 2021 | 01:29 PM
Stonedpony's Avatar
Stonedpony
This is going to be a trip to the dealer to scan your system as this is an Anti-Theft problem.
P1260 FORD code description The P1260 code can be set if the Passive Anti-Theft System (PATS) has determined a theft condition existed and the engine is disabled or an engine start was attempted using a non-PATS key. This Diagnostic Trouble Code (DTC) is a good indicator to check the PATS for DTCs. This DTC can also be set when a new Instrument Cluster (IC), Instrument Panel Cluster (IPC), or Powertrain Control Module (PCM) is installed without correctly programming either module even if the vehicle is not equipped with PATS.
79n40z
Oct 22, 2025 07:08 PM
ArmamentDawg
2015 - 2020 F150
Oct 8, 2018 01:36 PM
ZiggysMom
2009 - 2014 F150
Dec 8, 2017 02:46 PM
s2gots
Sep 14, 2007 11:20 PM
mdutra
Jul 18, 2007 06:20 PM
