Easy Entry/Exit Disable
Old Oct 14, 2021 | 07:51 PM
dugals's Avatar
dugals
Picked up my 2022 F250 Platty and going thru all my preference settings. One setting is giving me problems – the Easy-Entry/Exit, where the seat moves back when you turn off the engine. The manual p.93 says to go Settings, Vehicle and select Easy-Entry/Exit to disable, however that option is missing. Anyone else have the same problem? Is this a Sync 4 problem? I hate to take it to the dealer for that petty problem (I’d like to wait for something more significant).
I looked on the 2017-19 and 2020-21 Forscan spreadsheets and didn’t see a match for that setting.
Thanks
Old Oct 14, 2021 | 08:04 PM
4wd6.7L's Avatar
4wd6.7L
Thanks
You are doing this through the dash screen, not the Sync screen, correct?
Old Oct 14, 2021 | 08:09 PM
dugals's Avatar
dugals
Yes, dash screen not sync. My mistake.
Old Oct 14, 2021 | 08:30 PM
BSHORT's Avatar
BSHORT
Top Answer: 5
I've seen it in my settings.
Old Oct 14, 2021 | 08:58 PM
morehouse7's Avatar
morehouse7
Same as F150s??
TSB Number:SSM 49861NHTSA Number:10198630TSB Date:June 5, 2021Date Added to File:July 1, 2021Failing Component:Electrical SystemSummary:Some 2021 f-150 vehicles may experience the easy entry/exit feature missing from the sync 4 touchscreen menu. This may be due to various software parameters in the accessory protocol interface module (apim). To correct the condition, downlo
Old Oct 14, 2021 | 09:06 PM
Doug Savage's Avatar
Doug Savage
My 450 shows it too.
Old Oct 14, 2021 | 09:26 PM
4wd6.7L's Avatar
4wd6.7L
Originally Posted by morehouse7
Same as F150s??
Well if it is like the F-150 then maybe it is in the Sync 4 menu. It used to be in the dash menu on the SD, I assumed it still is.
Old Oct 14, 2021 | 10:49 PM
texrun40's Avatar
texrun40
Mine is in instrument cluster menu.
Settings/vehicle/Advanced Settings
Old Oct 14, 2021 | 11:10 PM
smikesF350's Avatar
smikesF350
?? Could it need at least one of the seat memories programmed via the buttons ??? Just guessing
Old Oct 15, 2021 | 03:24 PM
dugals's Avatar
dugals
Stupid me!! The manual says use the touchscreen. I'm embarrassed. Thanks
cfranc
May 24, 2010 01:00 PM
jwh2car
2009 - 2014 F150
Oct 31, 2009 04:37 PM
Buckgavin
1997 - 2003 F150
Jan 17, 2005 09:10 AM
chonka
Nov 5, 2004 03:05 PM
69crewcab
Apr 9, 2004 05:40 AM
