1" Rear Block
Old Oct 13, 2021 | 10:38 AM
JayCarver's Avatar
JayCarver
1" Rear Block
I have a 2020 F350 CCLB with a Carli 3.5" Pintop system with the Full replacement rear Deaver spring packs. This eliminates the factory blocks completely, the leaf's sit right in the perch.
I want to add a 1" block to the rear. Has anyone seen a good 1" block for sale? Do I want tapered? Flat?
Thanks in advance!
Old Oct 13, 2021 | 01:03 PM
speakerfritz's Avatar
speakerfritz
my 2019 f-450 had a 1" block. flat. but, the pin and the pin holes was larger than SRW blocks.
PMS fabrication can make blocks but I think they start at 1.5"
Old Oct 13, 2021 | 03:14 PM
SFSTROKER's Avatar
SFSTROKER
Maybe look into the leaf spring shims that One Up Offroad sells. The have several different thicknesses up to 3/4" I believe they can be stacked to achieve your desired ride height.
Old Oct 14, 2021 | 04:04 PM
jackfordsd350's Avatar
jackfordsd350
Did you remove the block in your 450? Are you running no block. Thanks
Old Oct 14, 2021 | 04:25 PM
speakerfritz
I replaced the 1” block with a 5” block.
Old Oct 15, 2021 | 07:21 AM
JohnD333's Avatar
JohnD333
Jay,
1-inch available from
https://www.pmfsuspension.com/2017-2...cks_p_173.html
I think they can talk you through whether a taper would be good with your setup..
Thanks in advance!
Old Oct 15, 2021 | 11:56 AM
JayCarver's Avatar
JayCarver
Originally Posted by JohnD333
Jay,
Awesome, thanks! Just what I was looking for.
I’ve been looking at their drag link for awhile also
Old Oct 15, 2021 | 12:24 PM
tsmithco's Avatar
tsmithco
I have the 1.5" PMF blocks on my CCLB 250. PMF told me that for the long bed, no taper for the 1.5", even though the factory 3" was tapered slightly.
Old Oct 15, 2021 | 03:54 PM
speakerfritz
The taper question is definitely confusing
factors are 2 piece drive shaft or 1
and
carrier drop bearing spacer or not
so, my understanding ,
for 2 piece it’s tapered or not tapered plus a carrier bearing spacer
for 1 piece drive shaft, it’s not tapered
and as stated above the DRW ubolts and bolt holes are bigger than SRW . On PMF website they ask about DRW or not
16_superduty
Sep 2, 2025 02:37 PM
ocwill11
Oct 29, 2021 10:51 AM
jav_eee
Dec 10, 2017 12:57 PM
brainchild
Oct 26, 2005 08:07 PM
