Baffling Baffles.
Old Oct 14, 2021 | 03:12 PM
Lane Locke's Avatar
Lane Locke
Unhappy Baffling Baffles.
1992 E 150 conversion. Took off the 3 pieces of plastic housing around the AC evaporator, and cannot find out how they go back on>
Also spent about two hours trying to find the transmission dipstick 3 books and a big flashlight. Had all the intake hoses off, but nowhere to be found.
Hours on the Web were not helpful - everyone's dipstick seems to be elsewhere than where MINE is.
Old Oct 14, 2021 | 06:06 PM
econo93's Avatar
econo93
.....spent about two hours trying to find the transmission dipstick 3 books and a big flashlight. Had all the intake hoses off, but nowhere to be found.
You're looking for a bright yellow plastic ring on the end of the dipstick. It's straight back from the 1" hose that connects from the snorkel to the air pump. It's up close to the firewall and kinda hidden by a large wiring loom and a hose.It helps to remove the nylon vac lines (3-in one connector) and the line to the MAP sensor for access but be careful that you don't break those lines!
Old Oct 14, 2021 | 08:19 PM
Lane Locke's Avatar
Lane Locke
No firewall? Doghouse situation.
Seems before it was behind the air cleaner, but it must have moved...
Old Oct 14, 2021 | 11:37 PM
econo93's Avatar
econo93
I have no clue as to what you mean here.
Maybe drive it to a Ford dealer so they can show you where it is?
Good luck.
Old Oct 15, 2021 | 07:48 AM
tabijan's Avatar
tabijan
Follow it from the transmission up.
Sixto
07 E350 5.4 176K miles
Antonm
Dec 28, 2021 02:19 PM
79F2502wd
Jul 2, 2021 04:55 PM
thekingofcows
Jul 2, 2012 10:16 AM
supercab79
Jun 3, 2010 04:38 PM
rbleiler
Sep 2, 2003 10:05 PM
