Ford 300 Straight 6 Overheating problem
Old Oct 13, 2021 | 09:51 PM
Zoink's Avatar
Zoink
My F150 Started to over heat when driving so I changed the thermostat and bled the coolant system now its sitting at 3/4 of the way (but not moving from there) on the temp gauge is that normal for it..
Old Oct 14, 2021 | 03:17 PM
FuzzFace2's Avatar
FuzzFace2
You need a way to "know" what the coolant temp is when this happens.
A cheap HF IR temp gun could work for this or an after market gauge.
It could be the gauge is flaking out or really be a cooling issue.
Once you know that we can look at how to fix it.
Dave ----
Old Oct 18, 2021 | 07:21 PM
john jamieson's Avatar
john jamieson
Is it possible some of the tubes in the radiator have become clogged?
Old Oct 19, 2021 | 10:28 AM
FuzzFace2's Avatar
FuzzFace2
Or the gauge or sending unit is bad
Again till you know what the coolant temp is you are just guessing it is hot..
Then again what is hot??
Could be coolant is 100°f and the gauge reading hot you don't know do we??
Dave ----
roller_steve
Jan 8, 2017 08:26 AM
mach6-300
May 15, 2010 09:35 PM
dscofever
Mar 23, 2010 05:49 PM
the1leadhead
Jun 14, 2009 04:15 AM
andym
Aug 23, 2004 01:02 AM
