2021+ F150 Discuss the 2021 Ford F150
Sponsored by: Real Truck
Forscan factory value needed
Old Oct 13, 2021 | 04:16 PM
2021Thor's Avatar
2021Thor
Hello,
New member looking for some help.
Looking for someone driving a 2021 F-150 XLT Supercrew 5.0L 3.73 gears with the stock 275/60/20 tires.
I would appreciate it if someone could check their Forscan records and let me know what the factory value is for tire circumference in mm, in the BdyCM Module. I made a change and neglected to record the original value.
Please help.
Thanks,
Bill
Old Oct 14, 2021 | 05:45 AM
2021Thor's Avatar
2021Thor
If there is anyone with a 2021 that came with 275/60/20 tires, who could share info on what this Forscan read factory value is, that would be awesome.
Besides needing it for my truck configuration, I’m curious if it’s different depending on engine and gears.
Any info on this stock tire Forscan read value would be very helpful.
Thanks.
Old Oct 14, 2021 | 06:41 AM
GABAR's Avatar
GABAR
Thanks.
I’m not sure if there is one but you might have better luck by going to the Forscan forum or website.
Old Oct 14, 2021 | 06:08 PM
2021Thor's Avatar
2021Thor
Good idea, I will try that also. Thanks.
Meanwhile, I hope someone on here with stock 275/60/20 tires on their 2021 F-150, will help me out.
Old Oct 24, 2021 | 06:56 PM
mhollem's Avatar
mhollem
There is also a website where you can get your as-built info. Just punch in your VIN and you'll get the factory as-built data.
https://www.motorcraftservice.com/AsBuilt
Old Oct 27, 2021 | 05:10 AM
2021Thor's Avatar
2021Thor
Yeah, I tried that, but the data was in hex, it wasn't user friendly.
However, a guy on the "14th Gen F150's" Facebook Group made the same suggestion and also offered to translate the hex for me. He did, and my "As Built" data in hex translated to 2547 for "Tire Circumference in mm."
Old Oct 31, 2021 | 07:57 AM
2021Thor's Avatar
2021Thor
Even though I have a number, I'm still looking to see what someone else has for that value from the factory. I would like to compare and get confirmation.
I'm sure there's someone out there who has a 2021 5.0L 3.73 gears with stock 275/60/20 tires, who also uses Forscan, or is considering using Forscan in the future. The "Tire Circumference in mm" number is in the user friendly BdyCM Module.
Thanks!
thunderbolt427
2004 - 2008 F150
Oct 19, 2023 09:56 AM
LiquidSteam
Jun 15, 2017 12:04 PM
FFJamison
6.7L Power Stroke Diesel
Mar 26, 2016 04:47 PM
technoman26
Feb 21, 2005 10:38 PM
