22 Tailgate won't open
Old Dec 4, 2021 | 07:59 PM
helifixer's Avatar
helifixer
wrong thread.
Old Dec 4, 2021 | 08:38 PM
KeystoneF350's Avatar
KeystoneF350
Originally Posted by tsimpson4472
Quick update - dealership said that the Linex bed liner was putting too much tension on the rubber bumpers and causing the gate to jam. The told me to have the coating removed from the area and it would be fine. I can't see that happening without a grinder and re-spray of factory paint, so I am going to keep an eye on the bumpers and see what happens.
No need to mess with changing the Lines liner. I just had the same issue with my Linex liner and my tailgate latch hanging up after my Linex was sprayed on my 2022. My tailgate was actually sticking out a bit past the taillights when closed, and so I trimmed 1/8" off the contact area of the rubber bumpers with a razor blade and the tailgate closes flush now. I loosened the tailgate latch posts and adjusted them as well so that the electronic latch easily releases and doesn't bind anymore. Sounds like your dealer is giving you bad advice on this issue since it's a pretty quick DIY fix.
killjoykarl
Aug 21, 2021 11:03 AM
BuiltTough45
Apr 27, 2021 11:42 AM
lwk362393
2015 - 2020 F150
Apr 17, 2021 10:42 AM
Warpburn
Aug 23, 2018 08:29 AM
finnf250
Feb 22, 2017 07:20 AM
