basement door replacement
Old Oct 13, 2021 | 08:52 AM
RV_Tech's Avatar
RV_Tech
One additional thought as I know folks want to spend as little as possible to don't forget the RV surplus suppliers like this one https://bontragers.com/rv-supplies-accessories/. There are many others and they can be shopped online or email. If you can pick up it really saves if what you need is large as "big truck" shipping is really pricey for small quantities. I have used them at times, especially if something is out of production. Finding the right part can often take longer than the actual repair.
Steve
Old Oct 13, 2021 | 06:18 PM
senix's Avatar
senix
heard back from Bontragers. They don't have the door.
I am working with Challenger to see if they will do something or have the direct replacement. Took a better picture of the label for the. Looks like Sep 2012 build date, so I don't think there is any warranty.
Old Oct 13, 2021 | 08:45 PM
RV_Tech's Avatar
RV_Tech
Colas RV Sales - huge RV salvage yard in Missouri. That is a really common RV. There has to be used compartment doors somewhere.
Old Oct 13, 2021 | 08:47 PM
HRTKD's Avatar
HRTKD
Colaw RV Salvage
https://colawrvsalvage.com/
They seem to be heavily oriented towards motorhomes, not trailers.
Old May 30, 2022 | 03:23 PM
senix's Avatar
senix
Reviving this post. I sought out Challenger door last fall. They had been bought out by Lippert of course. Had to wait until the 1st of the year so they could make the door due to parts change overs and new ways of doing things,
Got the door in late Feb but too cold to install.
Got it done today!
The old before removal
Point of failure
new door part number
inside of new door with the latches it came with
New door where I have it ready to join the frame
just the new frame installed.
senix's Avatar
senix
new door installed.
Old May 30, 2022 | 03:29 PM
senix's Avatar
senix
So what I learned in case others want or need to replace a door: I didn't realize the door can slide off the frame Just two rivets at each end of the hinge to drill.
Then the door can be slide out. If I had discovered that I would have attempted to just replace the door and re-use the old frame. May or may not have worked.
Once i discovered they can be taken apart it was easy to lift the frame in place and screw it in.
Then slide the door on, Two rubber piece at each end of the hinge to put in place. These little rubber pieces act as a keeper for the door and keep it aligned. New door they were screwed in so easy enough to put the screw back in.
Door locks are different and did not come with a key so I re-used the old locks.
Old May 31, 2022 | 11:11 PM
CathedralCub's Avatar
CathedralCub
FTE Community Team
Looks nice!
Thanks for showing us how it turned out!
emerald1
17
Sep 19, 2021 07:48 PM
adams1492
2004 - 2008 F150
20
Oct 21, 2014 04:57 PM
superduty4x4
57
Oct 29, 2008 02:39 PM
fordtrucksforever
30
Mar 30, 2008 11:55 AM
