2K Primer?
Old Nov 3, 2003 | 06:31 AM
Sore Knuckles's Avatar
Sore Knuckles
2K Primer?
Started bodywork on my 56. Blasted and sanded off at least 6 coats of old paint and got it all to bare metal. Got some metal prep and self etching 2K primer (mfg by 5 Star). I don't have a great deal of paint experience (mostly old tractors, trailers and the like) but I have never used any high build primer. When I sprayed this stuff it had a very rough texture. I realize I will need to block sand but is this rough texture normal? I adjusted air pressure and paint flow. I even tried reducing and spraying on some old scrap metal just to see if that would give smoother consistancy. I'd appreciate any advice you might have. Thanks
Old Nov 3, 2003 | 08:40 AM
Carlene's Avatar
Carlene
Admom
Sounds like you're either using too much hardner or got a bad batch of hardener.
I'm using PPG and got a bad hardening agent that gave me the same results. Had to knock it all down to a smooth finish and respray.
Old Nov 4, 2003 | 05:38 AM
Sore Knuckles
Thanks Carlene... I "borrowed" a 2 quart glass mixing bowl from wife so I could insure an accurate mix of primer and hardner. (I am still paying for that little stunt!!) I will try another can of hardner. Thanks again.
Old Nov 23, 2003 | 05:58 PM
stoutford's Avatar
stoutford
Thats what self ecthing primer does. Its supposed to mainly cover rust and finish rough. It would be best to block sand and then apply a primer surfacer, which would be sanded with fine grit 400 and apply the top coat
Old Nov 23, 2003 | 07:09 PM
daimon1054's Avatar
daimon1054
I agree with stoutford it is always pretty rough.
Old Nov 25, 2003 | 07:34 AM
Huntsman's Avatar
Huntsman
You may be using too small of a nozzle.
Old Nov 25, 2003 | 12:04 PM
darkman's Avatar
darkman
I'm not trying to be funny as I don't have a clue BUT why would you want to cover rust and end up with a rough finish? I thoght the high fill was supposed to fill small imperfections and have a self leveling feature.
nikmish
Paint & Bodywork
15
Mar 18, 2013 03:27 PM
dart7383
Paint & Bodywork
Jul 6, 2009 05:16 PM
73FOMO
Paint & Bodywork
Apr 30, 2007 06:07 PM
securitydog1
Paint & Bodywork
Nov 17, 2005 08:44 PM
rompin78
Paint & Bodywork
Jan 1, 2005 10:05 AM
