Fuse location
Old Oct 10, 2021 | 03:55 PM
Watcher58's Avatar
Watcher58
Fuse location
I have a 2003 V-10 and I assume there is a fuse for the backup lights. The crappy #@!%&%$@# manual only shows one for the diesel at position 8. I swear this X has been nothing but a PIA for weird stuff. Anyone know? Thanks
Old Oct 10, 2021 | 04:45 PM
Tunafish389's Avatar
Tunafish389
Fuse 27 for sure for a 2002 not sure if they changed in 2003.
Old Oct 10, 2021 | 06:09 PM
Watcher58's Avatar
Watcher58
Thanks you got it. My manual says 27 is ignition switch run feed. I kid u not. Weird stuff happens
Old Oct 10, 2021 | 07:24 PM
projectSHO89's Avatar
projectSHO89
F27 powers a whole lot of things, not just the backup lights. If it were blown, you'd be experiencing a lot more issues that are far more obvious than no reversing lamps. You did not mention any of those so it's highly unlikely that the fuse is your issue.
CJB F27 is a feed off the ignition switch that is a HOT IN RUN circuit, therefore its "description" in the owner's manual.
Old Oct 10, 2021 | 09:37 PM
Tunafish389
Here this might help for future reference again for 2002 but might apply to other years. Page 93-1 dealt with the reverse lights.
File Type: pdf
Old Oct 11, 2021 | 08:02 AM
WE3ZS's Avatar
WE3ZS
Reverse lights on the EX or for a trailer? I ask because the diesel EXs came setup for trailer reverse lights but the gassers have to add a relay and fuse to make them work.
Old Oct 11, 2021 | 02:13 PM
01__Excursion's Avatar
01__Excursion
Is the wire for reverse lights that you refer to actually there to be used in reverse to trigger a surge brake solenoid? Or, either/or?
Old Oct 11, 2021 | 03:51 PM
projectSHO89
No one said anything about trailer lights. Let's not confuse things more that already done.
Old Oct 11, 2021 | 04:14 PM
Tunafish389
I know my gassed has reverse trailer lights, maybe someone added before I got it. If you look at the pdf 13-5 it shows relay k357 and fuse 38 for the reverse trailer lights.
h20ford
Dec 9, 2018 12:27 AM
h20ford
Dec 9, 2018 12:25 AM
Gundown64
2004 - 2008 F150
Sep 23, 2012 07:47 PM
Cratos
Nov 16, 2009 08:10 AM
mmmPowerStroke
Jan 4, 2006 07:14 PM
