she is missing some horsepower
Old Oct 10, 2021 | 11:36 AM
Hartwig's Avatar
Hartwig
What do you think? The truck (2003 6.0) does not have enough power, the turbo was renewed. EBP, Baro should be the same as MAP KOEO, right?
The picture shows KOEO.
Old Oct 10, 2021 | 11:43 AM
bismic's Avatar
bismic
The 2003 does not use the EBP sensor output assuming it has had the PCM flash update issued in 2006 (and almost ALL 03's have it).
Old Oct 10, 2021 | 11:57 AM
Hartwig's Avatar
Hartwig
Hi Mark,
non original PCM is installed. The two VINs (truck and PCM) are not identical.
Here are the codes (an EGR delete and new turbo was installed last week).
#7 code I´m working on. Did oil change with Archoil.
Thank you
Old Oct 10, 2021 | 12:38 PM
bismic's Avatar
bismic
The P132B code means that it has the inferred EBP flash.
It means that there is a problem with the VGT system. P132B is a fault code that is set if the required boost levels are not achieved during a learn cycle or at specific speed fuel demand points. This code indicates that there are issues with the turbocharger, MAF sensor, MAP sensor/hose, IAT2 sensor, intake leaks, or exhaust leaks, etc. Frequently it is a sticking turbo issue. This code can also throw a P0401 EGR code.
On these vehicles, the MAF is used for fuel correction. The PCM will learn MAP and MAF and then learn the VGT action by cycling the VGT duty cycle in steps from 85% to 0%, and then back up, again in steps. It will learn the MAP and MAF action during this process. It takes 5 cycles to learn the VGT. P132b will be set if the PCM determines that there is something wrong with what it learned for MAP and MAF as it relates to VGT duty cycle.
Also, as you stated, something is going on with #7 injector/cylinder
Old Oct 11, 2021 | 01:07 PM
Hartwig's Avatar
Hartwig
Mark, were these MAF sensors used on 03 trucks?
Old Oct 11, 2021 | 01:20 PM
bismic's Avatar
bismic
yes .
Old Oct 11, 2021 | 08:30 PM
Fuzzpuss's Avatar
Fuzzpuss
Speaking of MAF sensors, I was shopping for one yesterday and it looks like Ford has discontinued them.
Old Oct 11, 2021 | 08:34 PM
bismic's Avatar
bismic
Look up: Part #: AFLS131 (12B579)
https://parts.ford.com/shop/en/us/el...assy-7818987-1
Old Oct 13, 2021 | 09:54 PM
Fuzzpuss's Avatar
Fuzzpuss
How is that useful for a 6.0L?
Old Oct 13, 2021 | 10:25 PM
bismic's Avatar
bismic
That is what came up in a search in their system for my truck (base part number is 12B579). Often times the pic is not correct, so I typically ignore it. Gas engine huh? Interesting
Old Oct 14, 2021 | 05:53 AM
Fuzzpuss's Avatar
Fuzzpuss
For the price I think I'll give the Delphi unit a shot:
https://www.rockauto.com/en/moreinfo...=5128&jsn=1892
6.0 DIESELS SUCK
Oct 27, 2019 06:42 AM
ChrisAU
Ford Truck Parts for Sale
Apr 10, 2013 09:56 AM
brownie83
Oct 27, 2012 01:23 PM
06powerstroke06
Mar 5, 2011 08:30 PM
hedhntr
Aug 5, 2010 11:25 PM
