Engine swap idea.
Old Oct 12, 2021 | 05:55 AM
Franklin2's Avatar
Franklin2
Originally Posted by Aaron296
If its worth saying this motor came out of a thunderbird
That tells me it does not have the rear sump oil pan setup for the trucks. So start looking for all that to convert it over. This place has all that if you want to pay for it. https://www.landlproducts.com/ Or a junkyard may have a 460 sitting around out of a truck.
Old Oct 15, 2021 | 07:10 AM
Aaron296's Avatar
Aaron296
Originally Posted by skaeke
I kept a front sump on my 390 when I put it in my bullnose. It works fine but it is a few degrees higher in the front than I'd like. I think doing it again I'd have put in a rear sump just for piece of mind.
So you put a front sump i a truck? if it possible i would prefer to not buy a oil pan. Also i started the motor yesterday and it runs great
Old Oct 15, 2021 | 08:21 AM
Franklin2's Avatar
Franklin2
I strongly recommend you not use a front sump pan. How will you change the oil? Some people have used a double sump mustang pan, and it fits without modifying the mounting the engine, but they can't get to the front drain plug to get all the oil out.
Old Oct 15, 2021 | 08:24 AM
Franklin2's Avatar
Franklin2
Here's some used oil pans for a 460 in Texas.
1988
Oil Pan
Ford Truck 250 5-88,7.5L,
X 9678 $85 Manuel's Used Auto Parts USA-TX(Pasadena) Request_Quote 1-800-435-5748 Request_Insurance_Quote
1128 1988
Oil Pan
Ford Truck 450 Series 7.5L
X 11646 $85 Manuel's Used Auto Parts USA-TX(Pasadena) Request_Quote 1-800-435-5748 Request_Insurance_Quote
1128 1983
Oil Pan
Ford Truck 350 10-07
X 07K063 $59.95 Williams Auto Salvage - KOLT USA-TX(Houston) Request_Quote 713-691-2015 Request_Insurance_Quote
1133 1985
Oil Pan
Ford Truck F350 W/PICK UP TUBE 000 A
0 535 $Call K & K Motors, Inc. USA-TX(Graham) Request_Quote 1-800-766-2009 Request_Insurance_Quote
Old Oct 15, 2021 | 11:37 AM
skaeke's Avatar
skaeke
I did. My project was similar to yours in that I wanted to spend as close to zero dollars as possible while doing the swap. I ended up chopping up the stock 351w perches I had and mounting them further up to clear the front sump pan. I have about 2k miles on the swap and I think if I could go back I'd have sprung for a rear sump. Which I believe is a fair bit pricier than a rear sump for a 460. Edit: I used the stock transmission mount to site the motor in the bay and ended up using a ~1" spacer under the transmission mount to lift the back of the trans trading some motor angle for driveline angle.
Pros:
  • Didn't have to buy rear sump pan
Cons:
  • Changing the oil is a tight job because the drain plug has enough clearance to get out but then the oil is draining directly on the crossmember. Tho you could use a fumoto valve and a hose setup to make it not messy.
  • You may have to fab up a custom fan shroud
  • I spent a lot of time treading the line of oil pan clearing the crossmember & not tilting the motor so much that is suffers from: oil starvation in the front cylinders (similar to what happens to a 300), the carb just leaking in to the manifold, driveline angle being too much.
So it worked out for me with a different motor but if the overall front depth(?) of your motor forces you to lift it higher it could be a disaster.
To sum up: Would not recommend but understand wanting to not buy a new sump setup. I personally may redo the sump and mount on my swap.
Jonathon
18
May 13, 2012 09:19 PM
fordnut forever
Jan 2, 2011 04:33 PM
59INA40
Apr 7, 2010 08:26 PM
smoke20
Sep 3, 2009 08:06 PM
AussieF250
Engine Swaps
Oct 26, 2006 08:46 PM
