Engine swap idea.
Old Oct 9, 2021 | 11:34 PM
Aaron296's Avatar
Aaron296
Engine swap idea.
So i got my 300 pulled out today (because #1 rod went through block and oil pan both) and i could put a different 300 out of a f-100 i have or I've got a 429 cobra jet that I could make fit, its a complete motor my grandpa was saving for his imaginary ranchero.
1970 429
Motor out
Old Oct 10, 2021 | 05:50 AM
FuzzFace2's Avatar
FuzzFace2
Check this thread out
https://www.ford-trucks.com/forums/1...5-f-150-a.html
Your transmission will not bolt up to the motor..
Dave. ----
Old Oct 10, 2021 | 07:12 AM
5starCabF-3's Avatar
5starCabF-3
That 429 is a great motor and I would jump at installing it....yes all the nay sayers will tell you,you have to change the transmission and motor mounts.
it definitely won't just bolt in to where the existing six is without work.
Old Oct 10, 2021 | 09:28 AM
Aaron296's Avatar
Aaron296
Well in terms of transmission the 429 already has a C6 bolted to it where it sits
Old Oct 10, 2021 | 10:27 AM
FuzzFace2's Avatar
FuzzFace2
Well that will help if you take it with the motor.
I dont know what trans is in the pick up but even if it is a C6 the bell housing on the 300 is a SBF and that other motor is a BBF.
I dont remember in that link if he also took the trans with the motor but think he did as I think it was a FMX he had to rebuild.
I am not a nay sayer and a lot depends on when he needs the truck up & running again and how much work he wants to put into making this happen.
If he needs the truck in a weeks time, dropping the other 300 in and having time to drink a few cold ones over rushing to get that big block in & running with no cold ones could be a factor
BTW does that BB have the right oil pan to clear the front cross member? If not then need to change it and the oil pump pick up.
Where do you think the exh manifold out lets will fall to get pipes on them?
Dave ----
Old Oct 10, 2021 | 02:42 PM
Aaron296's Avatar
Aaron296
motor
Old Oct 10, 2021 | 05:00 PM
Franklin2's Avatar
Franklin2
Here are the conversion mounts if you do not want to build them yourself.
https://www.landlproducts.com/detail...=0&ItemID=1026
Old Oct 10, 2021 | 05:42 PM
FuzzFace2's Avatar
FuzzFace2
Do you see something wrong with this pictures?
and this one?
Yep need to change out the oil pan and pick up
Dave ----
Old Oct 10, 2021 | 11:32 PM
Aaron296's Avatar
Aaron296
Dave ----
yea i saw that, ill have to look around and see what i got, but could I somehow use some 460 motor mounts I have out of a 84 E350 RV.
Old Oct 11, 2021 | 08:43 AM
FuzzFace2's Avatar
FuzzFace2
I don't know on the mounts as I have not done this swap.
Dave ----
Old Oct 11, 2021 | 08:58 AM
skaeke's Avatar
skaeke
I kept a front sump on my 390 when I put it in my bullnose. It works fine but it is a few degrees higher in the front than I'd like. I think doing it again I'd have put in a rear sump just for piece of mind.
Old Oct 11, 2021 | 09:36 AM
Franklin2's Avatar
Franklin2
They may indeed work, I think the E series has the same frame setup up front. Which reminds me your f150 won't have the dent in the crossmember for the oil filter adapter clearance. When Ford put the 460 in these trucks (the f250/350) they put a special dent in the front crossmember, and put a special oil filter adapter on it for oil filter clearance. Since you don't have the dent, and probably don't even have the special adapter, people just buy a aftermarket remote oil filter kit. I think you need a certain type that has right angle fittings to clear.
Old Oct 11, 2021 | 12:52 PM
Aaron296's Avatar
Aaron296
If its worth saying this motor came out of a thunderbird
Old Oct 11, 2021 | 04:45 PM
5starCabF-3
The 1969 Thunderbird and Mercury Marquis got a 11-1 CR 429 and were incredible. There Were 10-1 CR versions as well.......
Old Oct 11, 2021 | 05:56 PM
thechief66's Avatar
thechief66
My dad has a 77F150 with a 429 out of a Marquis...that thing will run circles around my 460!
