98 2.5 odd maf problems, confirm?
Old Nov 3, 2003 | 12:34 AM
stRanger706's Avatar
stRanger706
whats up yall, im PJ
i got a 98 2.5 5spd, 66k. 2nd ranger, just bought it a couple weeks ago. ok if the mass air flow sensor is plugged in, the truck starts fine and idles smooth, but if i give it any gas it bogs down and dies. resetting the ecu did nothing. if i unplug the sensor, reset ecu, then it idles rough, and sometimes stalls, but above 1000rpm its strong and smooth. i just drove it 600 miles with the sensor unplugged; i couldnt even tell except that it idles rough and occasionally stalls. ive done tons of reading on this site about the mass air flow sensor, and i think that it is bad/dirty. does this seem corect? just wanted some 2nd opinions. thanks guy, awsome board here
Old Nov 3, 2003 | 09:19 AM
ctfuzzy's Avatar
ctfuzzy
"Dirty" is certainly where I would start, PJ. Them dang things are expensive!!
HTH.
Old Nov 3, 2003 | 11:52 AM
wolfen's Avatar
wolfen
Welcome to FTE stRanger706,
Adding to ctfuzzy's advise, be careful when cleaning your Mass Air Flow (MAF) sensor element...IT IS VERY DELICATE!
DO NOT TOUCH IT AT ALL!
I disassembled, inspected; using a magnifying glass + spray electrical contact cleaner then reassembled the black-box devise! (others have also used carb cleaner + had positive results)!
______________________________________________
Hey ctfuzzy,
All electrionc devices are expensive! A'mi'go!
‘90 Ranger XLT: 2.3L, EEC-IV, EFI, DIS, 2wd, Mazda 5sp
Old Nov 3, 2003 | 01:27 PM
ctfuzzy's Avatar
ctfuzzy
Originally posted by wolfen
Hey ctfuzzy,
Well, actually RAM is dirt cheap. In fact, I have about $500.00 worth in this computer, that you can now buy for about $120.00 in any number of $%&^% places
Old Nov 3, 2003 | 04:12 PM
stRanger706
ok, i bought some intake/throttle body cleaner to clean the sensor with. that seems to be what everyone else did. ill let yall know how it turns out.
Old Nov 4, 2003 | 10:58 AM
stRanger706
grrrrrrrrrrr that wasnt the problem. truck still ran like crap after i cleaned the maf, reset computer. it wont go over 1500rpm with the sensor plugged in. i unplugged it and i guess the computer goes into some sort of default program because it runs a lot better with it unplugged. it looked fine to me when i cleaned it but do these sensors go completely bad? anybody?
Old Nov 6, 2003 | 07:11 AM
blur9050's Avatar
blur9050
I just had the exact same problem in my 99 2.5
I ended up having to replace my MAF and its only about $128 from ford. I would say that you are going to have to replace yours too.
Old Nov 6, 2003 | 01:10 PM
wolfen's Avatar
wolfen
Pull them computer codes yet?
_______________________________________________
Old Nov 6, 2003 | 03:47 PM
blur9050's Avatar
blur9050
How do you pull the codes off of these trucks? I know how to pull them off my stang, but i have no idea on my truck. Is there a way to do it with a multimeter like my mustang? Otherwise I'll just head to Autozone from now on.
Old Nov 6, 2003 | 05:45 PM
Ken00's Avatar
Ken00
99s are ODB-II which require a scanner.
Old Nov 9, 2003 | 03:40 PM
stRanger706
wolfen, no i havent had a chance to pull the codes. been pretty busy with school and such. ive been limping around town with the mafs unplugged until i can afford a new one. i think with the sensor unplugged it seems to be running rich. besides mileage, will this hurt anything else? foul the plugs? o2 sensors?
Old Nov 9, 2003 | 04:40 PM
ctfuzzy's Avatar
ctfuzzy
stRanger706, get to Autozone.
There is one (or more) within about 10 minutes of campus.
You *could be* hurting all kinds of stuff including the catalytic converter . . depending on how much longer you procrastinate
Old Nov 9, 2003 | 04:52 PM
stRanger706
ok, ill go tomorrow morning. but i wont be able to buy a new one for at least 2 weeks. cheapest i found was fordpartsonline.com for $135.
Old Nov 12, 2003 | 03:55 PM
stRanger706
autozone wont pull any codes unless the check engine light is on. mine hasnt come on.
Red454sedgwick
Modular V8 (4.6L, 5.4L)
Sep 14, 2014 08:51 PM
njf207
Jun 8, 2011 09:44 AM
Stan's 04
1997 - 2003 F150
Feb 7, 2011 09:02 PM
jemini
Nov 24, 2007 08:25 AM
tmcd
Illinois Chapter
Dec 21, 2004 04:45 PM
