250 or 350
We have ordered a 250 Lariat with a 6.9 box. The main reason we purchased this is to pull our 28 ft Airstream camper. It has a tongue weight of about 900 and we use a Blue Ox hitch. This is our 4th camper over the last 20 years so we have 1000’s of miles under our belt towing. We have seen several photos of flipped campers and are now wondering if we should order a 350. I’m sure we are sufficiently powered with the 250 but what do we gain if we upgrade to a 350? We had a ProPride hitch on our previous camper and when we purchased the new camper the dealer suggested the Blue Ox. We are still towing with the Expedition until the new truck comes in. This will be my daily driver, but I don’t drive than 7000 miles a year. Will the 350 be a much rougher ride? I should also mention that I ordered the 7.3 motor and the camper package.
Thanks,
More later,
Jim / crewzer
CAMPER PACKAGE (471) Availability: ●Optional on XL, XLT, Lariat and King Ranch® (DRW only), Platinum (DRW)
Not available with:
●20" Wheels and Tires
●Pickup Box Delete (66D)
●Heavy-Service Front Suspension Package (67H)
★Tremor Off-Road Package (17Y)
Includes:
●Extra heavy-service front springs (4x2) (2 up upgrade above the spring computer selected as a consequence of options chosen. Not included if maximum springs have been computer selected as standard equipment)
●Heavy-service front springs (4x4) (1 up upgrade above the spring computer selected as a consequence of options chosen. Not included if maximum springs have been computer selected as standard equipment)
●Rear auxiliary springs (F-250 only; Std. on 350)
●Rear stabilizer bar (SRW only)
●Slide-in camper certification
Not available with:
Includes:
But, in some states, the 350 takes a massive hit in registration costs and insurance.
As a side note, why would you switch from a ProPride to anything from Blue Ox? Propride is the absolute best for sway.
Thanks,
good luck
Thanks,
Below is my '18 350 diesel SB. The 25' AS has a ~900# TW.
Recent scale ticket
If you hit the highway a lot I would skip the camper package and get a 350 srw 7.3/3.73.
With the camper package I would consider putting the 2019 rear blocks in it as the front will sit a little higher. I would upgrade shocks personally.
I find that highly unlikely. I believe the fictional dry hitch weight of those trailers is about 900 lbs. Make sure you're not being conned into looking at those silly dry weights. It's about the same as asking a 50 year old man how much he weighs and getting a reply of, "Well, I weighed 160 lbs in high school."
I also added the snow plow/camper package and the HCTT package along with the 18" AT tires. These packages actually made the truck a 350, but with the badging for a 250, and of course a derated GVWR (10800 vs 11500). Mechanically there is no difference now between my truck and a 350, except the badge and the yellow door sticker. I say this because I am actually quite pleased with how the truck drives/rides. Before I rented a 250 last year for a long camper tour I had no clue what the deference between a half ton, 3/4 ton or a 1 ton was. When the rental place told me the night before that they only had a 1 ton in stock I thought "Wow! This thing is way bigger than even the 250 I thought I was getting!" Turns out, when I showed up the next morning they had a 2020 6.7 F250 with 52 miles on it they gave me. That's when I knew I wanted this truck for myself! But I was still expecting a 350 to be so much worse when driving...
Well, now that I have my own truck and is configured exactly like a 350, there's not difference, and I was pleasantly surprised in how good I think it rides. Don't get me wrong, it's no luxury car type of ride... our Pathfinder (platinum) was actually a really comfortable ride, but I have no complaints with mine. I did air down the tires to around 50 psi for driving around town, but other than that, nothing has been changed. I figure I may change out the shocks in a couple of years, which I hear also helps... But, the ride quality of these are good in my opinion... of course this is subjective though.
Anyway, being that my truck is over the magic 10000 number, my truck will also be subjected to all the licensing and registration fees like that of a 350, and in this case, I should have just went with a 350 I guess... but, it was several hundred dollars less expensive to get my truck built this way than to start with a 350, and also, for whatever reason, an F350 would have made my insurance rates higher according to my agent. So, in the end, it did cost me less money to stick with what I have. I have seen a lot of threads and talk about no one has ever seen anyone buy a 250 and not say I wish I would have just gotten a 350... well, I am one of them. If I had to do it again, I would go this route again and get another 250 with the add ons. I have 3016 lb payload and only plan to use less than 2000 lbs, so I have plenty left, even to upgrade to the slightly larger Airstream if we ever do so. I also don't mind going all the way to my max payload and GVWR since I know that my truck can handle more being that it is no different from the higher rated 350.
I'd say for what you want to do with it, I would stick with the 250. Being that you got the 7.3, you will end up with about the same payload rating as I did. Mine is an XLT with no heavy add ons though, so it depends on what you added to your Lariat. As for hitches, while I haven't used either, I agree with the others, the PP is a better hitch than the Blue Ox. For me, I went with an Anderson WDH. I was using an EAZ Lift hitch that the dealer gave me when we bought ours, which has been a good WDH, but it was time to replace it. Besides, my new truck has a 3" receiver, and I wanted a WDH with a 3" shank so I didn't have to use the reducer sleeves. I should get it hooked up next week and start using it soon after to see how I like it.
Anyway, good luck in your decision... with that camper I don't think you will go wrong either way!
