250 or 350
Old Oct 10, 2021 | 10:09 AM
Sonny Crockett's Avatar
Sonny Crockett
350. It's maybe $900 more. Get the best.
Old Oct 10, 2021 | 03:10 PM
Deano_1's Avatar
Deano_1
Originally Posted by crewzer
The differences between a modern F-250 and F-350 SRW range between significant and essentially zero. Tell us more about your F-250 configuration: which engine, major options, etc.
More later,
Jim / crewzer
For those of you that asked what I order on the 250. I ordered the Super Cab with the short box, 7.3 motor, 3.73 electronic locking axle ratio, 4x4, 10,000 GVR, Camper Package, Chrome Package, 4x4 Off Road Package and Dual Battery.
Thanks for all the responses!
Old Oct 10, 2021 | 06:19 PM
arniet's Avatar
arniet
Just to really muddy the waters, you can order an F350 with a 9900# gvw. Many of these creations are for fleet customers, who have very strong reasons to order some of the strangest things. Strong reasons to order an F250: Homeowners assoc. rules, hammer lanes in the east on interstates, parkways in NY, NJ, and MD. A weird reason is that some states can (I say can) make you scale an over 10k vehicle with commercial plates, and in WV (my home) if it is over 10k you get "B" plates which are considered by the surrounding states to be commercial. Just as an aside, 11k commercial plates are cheaper than the 10k or less for your car.
For your needs you are good. I pull a 5er with a 2012 F250 with a 6.7, even loaded with 2 extra spare tires, a full deck tank and the 5er loaded with water I am still 300# under on the truck. My 5er is a rear kitchen with 2 of 3 tanks behind the wheels, so she is light on the pin at only 1600#. Load er up, hit the road and drive. We have finished the lower 48 and most of Canada. We rented a truck camper in Alaska, otherwise this rig has seen a lot of miles. I have a truck very similar to yours on order right now, see you on the road.
Old Oct 10, 2021 | 06:46 PM
Deano_1's Avatar
Deano_1
Originally Posted by 67L48
Go from the other direction. Rather than ask us if you should get an F-350, instead tell us why you opted for an F-250 ... particularly since you were/are ordering. The reasons you chose an F-250 could be important.
I find that highly unlikely. I believe the fictional dry hitch weight of those trailers is about 900 lbs. Make sure you're not being conned into looking at those silly dry weights. It's about the same as asking a 50 year old man how much he weighs and getting a reply of, "Well, I weighed 160 lbs in high school."
The tongue weight is right on the Airstream spec sheet. 2017 Flying Cloud 28 foot RBQ. This doesn't include the two 30 propane tanks and two batteries.
Old Oct 10, 2021 | 07:54 PM
67L48's Avatar
67L48
Originally Posted by Deano_1
The tongue weight is right on the Airstream spec sheet. [...]
That's exactly my point. That's a worthless number that has little to do with what weight will actually be on your hitch. It doesn't include your cookware, the factory options that were added (A/C, upgraded cabinetry, etc.), the options the dealer may have added (like the batteries you mentioned), your clothes, your food, water, leveling gear, tools, and on and on. If you're quoting fictional dry weights as if they have anything to do with reality, then you're not thinking through this properly.
Back to the main question ... rather than the rest of us selling you an F-350, tell us why you went with an F-250. The reasons that put you on that path are important.
Old Oct 10, 2021 | 09:28 PM
Joe T's Avatar
Joe T
You can only get the 3.73 with 7.3 in a 350. You can option the 10,000 gvwr package in the 350.
If that is the gear you want I would suggest skipping the camper package and getting the 350 and option the 10,000 gvwr option if needed. Its not much more and brings a higher rear gawr.
Do you plan to put a shell on the bed and/or haul a lot of weight in the truck? The 250 7.3/4.30/camper pack is a good value but the 350 7.3/3.73 isnt much more.
With your limited miles and trailering I would go with the 250 7.3/4.30 camper or 350 7.3/3.73.
Old Oct 11, 2021 | 10:25 AM
DaveZX's Avatar
DaveZX
250 or 350
Flipped campers are more about the driver of the tow vehicle than the truck. A Super Duty with a good weight distribution (sway control) hitch should easily handle the TT.
Old Oct 12, 2021 | 08:34 PM
Deano_1's Avatar
Deano_1
I don’t plan on having a shell. I do have to 7.3 with the locking 3.55. I don’t plan on hauling a lot of extra gear. A few boxes of firewood a dog pen and a small camp table and occasionally a Honda 2000 generator.
Thanks
Old Oct 12, 2021 | 09:36 PM
Joe T's Avatar
Joe T
I would only get the 3.55 if it was a commuter truck putting down highway miles unloaded.
Old Oct 12, 2021 | 11:59 PM
440 sixpack's Avatar
440 sixpack
I pull a heavy gooseneck in the mountains all the time with 3.31's and I love them. I have 10 gears that's what they're for.
Old Oct 13, 2021 | 06:53 AM
bent-1's Avatar
bent-1
I drive 60,000 miles + / year split among a gooseneck & tongue pull flat deck trailer with either a F250 or F350.The heavier rear springs as you ordered seem planted and in control. The base F250 is a little loose imho.
Old Oct 13, 2021 | 07:50 AM
Joe T's Avatar
Joe T
And your diesel has double the torque.
Favored
Apr 18, 2019 07:27 AM
stro1965
6.7L Power Stroke Diesel
Apr 9, 2012 11:45 PM
Fishingdad
Feb 24, 2011 02:18 PM
CPT_Diesel
All Things Towing
Jun 23, 2007 11:25 AM
FordPowerStroke
Aug 10, 2005 06:22 PM
