51 F1 headliner pattern
Old Oct 7, 2021 | 09:42 AM
bobsled46's Avatar
bobsled46
I need a headliner pattern fir my F1. I have previously found a number of links to this issue but they are no longer any good. The one that is still viable is a PDF but doesn’t have any dimensions ( sorta useless without them).
Any help would be greatly appreciated
Old Oct 7, 2021 | 10:41 AM
ALBUQ F-1's Avatar
ALBUQ F-1
The PDF version is a full-size pattern that can be printed at a blueprint shop, and used to cut material directly from. It would be impossible to adequately dimension it because of the shape.
Old Oct 7, 2021 | 10:48 AM
tip49's Avatar
tip49
I used this pattern to make my templates to layout on pvc material. I don't recall having any issues with it. I "formed," the top section to fit the contour of the cab corners by heating the material.
Old Oct 7, 2021 | 11:47 AM
bobsled46's Avatar
bobsled46
Thanks for the info
So not being real computer literate, do I download the pdf on a stick and carry it to a blueprint shop?
Old Oct 7, 2021 | 12:45 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Talk to your local blueprint shop, but that should work. Make real sure they print it full scale, and check the fit with the pieces cut from the paper before cutting material! Tom may have better tips, I ended up buying the Dennis Carpenter kit. Done in a day.
1952henry
Nov 22, 2014 07:51 AM
tubbys50
Aug 8, 2010 07:02 PM
Dustydude
Jun 2, 2006 07:34 AM
ABOERNER
Mar 6, 2001 05:00 PM
