Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
534 distributor
Old Oct 6, 2021 | 08:09 PM
Kb1950's Avatar
Kb1950
534 distributor
Hello everyone! I'm working on a 534 in a 1974 l880 truck that had a blown head gasket. In the process I cant get the distributor to budge. I'm probably going to break it to get it out. What other distributor will fit in this engine? Is the y block the same? I can't seem to locate one for a 534.
thank you
Old Oct 6, 2021 | 10:52 PM
85e150's Avatar
85e150
Welcome to FTE! Soak it in penetrating oil. I'll be right back regarding the distributor.
Old Oct 6, 2021 | 11:53 PM
85e150's Avatar
85e150
Post 4--do you have a points type distributor:
https://www.ford-trucks.com/forums/1...l#post18806229
I could find nothing else about distributors and if they interchange with any other series like FE or Y. It was said you could get a rebuild at NAPA. I found an electronic one:
https://www.napaonline.com/en/p/NRD4...pressionRank=1
Part number NRD 4822890
That might be complicated to make work due to the electronics.
I would try not to break the one in there.....
These are tough to get parts for.
Old Oct 7, 2021 | 05:44 AM
Kb1950's Avatar
Kb1950
It's a points distributor. I don't want to break it but it's not moving at all. Been soaking it with pb blaster for about a month now.
Old Oct 7, 2021 | 05:52 AM
Kb1950's Avatar
Kb1950
I found this one on napa too and it looks right. NRD 4822834
Old Oct 7, 2021 | 01:17 PM
Destroked 450's Avatar
Destroked 450
I don't know of any distributor that fits but one for a 401, 477 or 534
I may be wrong as it's been a few years, but I don't remember removing the distributor when I pulled the intake and left head on the 534 I had
But old timers memory isn't helping
Old Oct 7, 2021 | 05:24 PM
Kb1950's Avatar
Kb1950
I did get it out. I heated around it with a torch and got it to break loose then it came right out luckily.
Old Oct 7, 2021 | 05:31 PM
85e150's Avatar
85e150
Good!
If you want to eliminate points, the Pertronix setup fits that distributor just as it does all the other Ford distributors. Serving suggestion.....
Good luck with it!
Old Oct 7, 2021 | 05:34 PM
Kb1950's Avatar
Kb1950
I'd be really happy if I could get 5mpg out of it lol
Old May 11, 2023 | 05:13 PM
max the dog's Avatar
max the dog
Trailering
401, 477 are the same
Old May 14, 2023 | 12:45 AM
garygnu's Avatar
garygnu
I got 5mpg on a 300 mile trip with my 534 SD ,the truck weighed 17,200 lbs .I averaged 2700 rpms for most of the trip,it has a 6.17 rear ratio and I was hill climbing and not down shifting
chris989
Sep 19, 2021 07:52 PM
cparks
Apr 18, 2009 06:57 PM
go2toa
Aug 15, 2006 11:07 AM
dillon1033
Feb 9, 2003 12:52 PM
kwieringo
Jan 17, 2002 12:37 AM
