Code 311 bypass?
Old Oct 6, 2021 | 02:38 PM
Toork's Avatar
Toork
Code 311 bypass?
Background/Build on my truck : https://www.ford-trucks.com/forums/1649210-97-long-and-slow-yacht-build.html
I recently removed my smog pump and ran a shorter belt. I am getting a KOER 311 thermactor code. Is there a way to bypass the electronics to eliminate this code?
thanks,
Old Oct 6, 2021 | 03:11 PM
rla2005's Avatar
rla2005
thanks,
No, there is no way to bypass that error except put everything back. It will not trigger a Check Engine Light (CEL) so just ignore it when running the KOER tests.
Old Oct 6, 2021 | 04:00 PM
Toork's Avatar
Toork
OK. I have a check engine light but also have a 327 code. I was trying to eliminate issues, but if 311 doesn’t throw a CEL, that helps! Thanks.
Old Oct 6, 2021 | 04:15 PM
rla2005's Avatar
rla2005
Code 327 is triggering your Check Engine Light.
Old Oct 6, 2021 | 04:49 PM
wwhite's Avatar
wwhite
yes, get a tuner, disable it in the tune.
Old Oct 6, 2021 | 04:51 PM
wwhite's Avatar
wwhite
is the EGR still connected?
Old Oct 6, 2021 | 08:09 PM
Toork's Avatar
Toork
yes. I watched a how to diagnose video today. Im going to see what I can find out tomorrow. I want to keep EGR.
Old Oct 6, 2021 | 08:10 PM
Toork's Avatar
Toork
what kind of tuner works on our trucks? Mine is OBDI
Old Oct 7, 2021 | 06:36 AM
rla2005's Avatar
rla2005
So a tuner can change which items are checked during the Key On Engine Running tests?
If it does have that function then I still find it an expensive option just to keep from seeing an error during the KOER tests.
sg1099
1997 - 2003 F150
Dec 21, 2010 05:17 AM
