2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
Upfitter switches changing on 2022 models?
Old 10-06-2021, 02:21 PM
BigUnixGeek's Avatar
BigUnixGeek
BigUnixGeek is offline
Question Upfitter switches changing on 2022 models?
I've ordered a 2022 F-250, but haven't taken delivery yet.
Upfitter switches is something i specified, and I've seen numerous applications of them in various places -- forums, youtube, etc. However, when browsing through the 2022 Super Duty Owner's Manual I found online as a PDF (dated April 2021, First Printing), I found that the upfitter switches seem to be different from what I've seen and read previously. Looking further, I found a document from Ford designated Q-252 which looks exactly like what I've seen previously, and definitely conflicts with the Owner's Manual I found.
More spedifically... Q-252 shows aux switches 1-4 have relays rated at 25A, and 5-6 have 40A relays. The Owner's Manual I have specifies the switches have relays fused at the following values, in order: 10A, 15A, 15A, 10A, 5A, 5A.
I was wondering if someone with a 2022 F-250 or F-350, with upfitter switches, could check their Owner's Manual (page 617 in my PDF) and under their hood, and see what they find there.
Thanks,
Rob
Old 10-06-2021, 02:26 PM
fordboy424's Avatar
fordboy424
fordboy424 is offline
I noticed that also. I downloaded and started reading the manual after I placed my order. I can confirm that the manual is wrong. My buddy got lucky and has his 22 f350 7.3 already and it has the 25 and 40 amp upfitter circuits.
Old 10-06-2021, 02:27 PM
Brantel's Avatar
Brantel
Brantel is offline
Typo in the manual...
Old 10-06-2021, 02:35 PM
Ltngdrvr's Avatar
Ltngdrvr
Ltngdrvr is online now
Received 3,385 Likes on 1,789 Posts
Yup, owner's manual is wrong.
Upfitter switches are the same from 2017 to present.
Old 10-06-2021, 03:44 PM
chamdaddy's Avatar
chamdaddy
chamdaddy is offline
Just about everything in the 2022 manual is wrong as it refers to the upfitter switches including the fuse amperage and location of the upfitter wires and pass thru wires. Call up a 2020 owners manual and it has the correct information.
Old 10-06-2021, 06:52 PM
rklavoon's Avatar
rklavoon
rklavoon is offline
The 2022 owners manual is jacked. I asked the same question a few months back.
Check out the thread here:
2022 Upfitter Switches don't have same capacity as previous MY - Ford Truck Enthusiasts Forums (ford-trucks.com)
Old 10-06-2021, 07:11 PM
BigUnixGeek
Any changes to the pass-through wires?
Old 10-06-2021, 07:16 PM
Ltngdrvr's Avatar
Ltngdrvr
Not since 2017, right side kick panel.
Old 10-06-2021, 08:23 PM
chamdaddy's Avatar
chamdaddy
Here is a pic of my 2022 F-350 upfitter fuse box and associated wiring. I have not gotten into the kick panel yet to locate the other end of the pass-thru wires, but there are several threads showing their location. I have already tapped into Relay#1 and there was plenty of wire to work with.
Old 10-06-2021, 08:45 PM
cpro24's Avatar
cpro24
cpro24 is offline
The only difference I see is on my 21 f350 the pass through wires are very short almost impossible to work with in the cab(been talked about many times) but on my 22 f350 the pass through wires are easy to reach and work with behind the pass side kick panel. Its almost like ford was listening to us and made them longer in the 22s....................... or maybee just s**t Luck
Bodaway
2017+ Super Duty
09-07-2021 11:59 AM
DDT11
2017+ Super Duty
08-28-2016 01:35 AM
kyleC9959
04-21-2004 03:45 PM
VinDiesel
10-28-2002 08:57 PM
Latebloomer
12-29-2001 01:09 PM
Quick Reply: Upfitter switches changing on 2022 models?
