Bronco Tailgate Rust
Old Nov 2, 2003 | 10:15 PM
ryanguglich's Avatar
ryanguglich
I was just wondering if people would share some insight as to how they fixed the rust problem on their tailgate. I have to fix mine and it's rusted from one end to the other
Old Nov 16, 2003 | 04:26 PM
BRI-GUY74's Avatar
BRI-GUY74
sOME PLACES sell a plate that has vents on it and you can place it over the damaged area.
Old Nov 16, 2003 | 06:28 PM
uk1050's Avatar
uk1050
you can just cover it but the rust is still there. the bad thing about tailgate rust is that the rust gets inside and short of cutting it apart you are never going to get all the rust. new ones arent that expensive.
Old Nov 19, 2003 | 06:35 PM
3broncocrazy's Avatar
3broncocrazy
Bronco tailgates are prob higher than pickup - also a PIA to change guts (window, gears etc)
If it is gone past surface rust, maybe junkyard. Several year mods are the same - and if your luck is better than mine, the inards would work from the donor
Old Nov 19, 2003 | 06:42 PM
3broncocrazy
YEA,
Big diff. 83-96 pick up $90. 83-96 bronco (shell only) $950 at broncograveyard.com
WOW
Old Nov 23, 2003 | 07:25 PM
blueoval78's Avatar
blueoval78
buy a new one, you will never get a good fix from a repair kit. aftermarekt ones can be had for fairly cheap, but they are just that cheap, and dont always line up good,
a good body shop is used to doing this kind of thing, and will usually take the time to work new drain holes and good prep on the inside
1985 Bronco
1978 - 1996 Big Bronco
Jun 15, 2016 01:41 PM
Stockdale Dave
Jun 14, 2016 06:57 PM
maddogjohnson
S. California Chapter
Jan 26, 2012 12:18 PM
killerkjn
21
Aug 12, 2011 08:21 PM
CHUCKS65PHUGLY
Jun 23, 2006 09:06 PM
