New 5th wheel
The following 4 users liked this post by Sanspy:
The following 3 users liked this post by ATC_F350:
The following users liked this post:
The following 3 users liked this post by senix:
The following 3 users liked this post by BSHORT:
I really like their construction and USA factory location, so I went with a B&W Companion for my 10K gross fifth wheel. Not as light weight as an Anderson or Goosebox system, but it easily breaks down into two 75 pound pieces that I can still handle by myself when I need a clean truck bed.
PSA on the B&W Companion. B&W does NOT allow it to be used with a locking wedge and rotating pinbox system (ie Reese Sidewinder or Lippert Turning Point) IF the hitch is connected to the truck with a single point (gooseball) connection. After a brief panic attack and call to B&W, I discovered you CAN use it with a locking wedge and rotating pinbox system, as long as the hitch is connected to the truck with a four point (factory puck) connection.
Good luck!!
Good luck!!
We have as well. Sometimes just walking around and seeing more and more 5ers with the Reese Goosebox. Haven't heard anyone complain about them, but have had several questions from traditional hitch owners about the hitch up, ride and chucking.
If only using the fiver sometimes but wanting to have the bed clear for other uses then I lean toward something like a goose box for ease in clearing the truck bed.
Doesn't hurt to double check if your camper is okay with being switched to a goose box before making the switch.
