Pressure Differential Wiring
My question is related to the brake pressure warning switch. The original factory wiring to the pigtail has 2 wires and the plug at the valve has two pins. The new Master Power Brakes Combo Valve switch has a single pin. I purchased the matching pigtail from the manufacturer which is a single pin and has one wire.
Does anyone have and ideas or suggestions for how to wire in a single wire pigtail so it works with the dash light? Is one of the two existing wires a ground which could be abandoned or possible grounded to the frame?
Thanks.
Does Master Power Brakes have any input on their way of wiring it up? Sorry not much help.
Temporarily connect both to the new pigtail, while the pigtail is loose.
Put the 'pin' in the pigtail to ground, then with the ignition on and engine off, check that the warning light comes on.
If it does, permanently fit all three wires together and fit the switch into the combination valve.
If it doesn't, time for a headache tablet.
The light should go off when the pin is not touching ground, and should stay off when the switch is permanently fitted.
Your one-wire switch on the new pressure differential valve sounds like it can only complete a ground. The switch grounds to your transmission, and the wire terminal is probably normally dead, and is connected to ground only when the pressure drops.
I'm not 100% certain of that, but I strongly suspect it.
If it is that way, then your warning light will need a constant source of ignition power so the PDV switch can turn on the light by completing the ground circuit. In this case, you would lose your warning light prove-out feature, and the light would only work if there's a loss of pressure. You would need a separate switch on the ground side to test the bulb.
I think the way a stock untouched truck does it, is that when you turn the key and crank the starter, the ignition switch sends 12V+ to the cluster, bypassing the PDV switch, and lights the light while you crank, so you can be sure the bulb is good.
6 by 8 I read it, I appreciate it, I even copied it for my FTE library later. Good stuff thanks.
And my BS comment which I thought was non BS, is in fact BS.
Ok, got it, thank you Gentz.
On a serious note, after I read Meangreen's 1st post, only then did I look at the wiring diagram, which by the way looks to be the same as a 1973 diagram in my Haynes book.
I then thought, as Meangreen did, that the wires were live going to the switch.
Seeing as I've never wired a 2 wired switch, I thought it best to call my comments BS to play it safe.
I hate making comments based on assumptions or on something I've read.
If Meangreen did in fact write BS, it was good BS.
A suggestion for STLRyan :
If you have the time, money, and inclination, and seeing as you are in the middle of a restoration :
Give the combination valve away.
Connect the front brakes via a T connector.
Connect a proportioning valve in the rear circuit. (Although it may actually not be needed.)
Fit an aluminum/plastic modern MC
Run the two wires that went to the OE combination valve to the reed switch built into the new MC
The benefits ?
1 You'll feel the improved braking without the combination valve, and the nose will not dive under hard braking.
2 If there is a brake fluid leak, the warning light will come on when the MC is still 50% full.
(I had two slow leaks in the rear drum cylinders over the years, and I only found out when the brake pedal went to the floor !
Luckily both times I had just jumped into the truck ready to drive off. The rear MC compartment was empty and no visual external leak at the rear.
You don't have cylinders anymore, but a leak is a leak regardless.)
3 A reguar visual check of the MC level is quick 'n easy.
I'll post up part numbers if you're interested.
Thank you again for the input!
The top right hand diagram is very helpful, but, briefly returning to the subject of BS, it just screams 'live' to me and not ground. LOL
Personally, I'd like to see an OE switch, wiring and gauge circuit board, to see for myself how it works.
Moving on swiftly !
Starting with the MC, I don't like the OE one, how it looks and how it opens, and I didn't like the fact that I could be coasting down a steep hill only to find I had no brakes without any prior warning.
So ! Safety is paramount, and that's why I fitted an aluminum/plastic modern MC, and wired it up to warn me of brake fluid loss. (as opposed to a pressure difference warning, which DOES NOT work as a useful warning anyway)
It makes NO difference at all to the braking feel and efficiency.
Your existing OE MC should have a 1.0625'' bore, and a 1995 Ranger MC would be used to replace it :
https://www.rockauto.com/en/moreinfo...t=1836&jsn=965
The 'funny' angle doesn't look too bad once fitted, and all you'd need is an M10 and M12 tube nut.
I used that one with a disc/drum combo for years.
My brake pedal always traveled a little bit more than an OE brand new vehicle. Nothing serious, but I noted it.
When I converted to disc/disc, I continued to use that MC for a while.
I then decided to try a 1 1/4'' bore MC, and I fitted this one from a 2002 F150 :
https://www.rockauto.com/en/moreinfo...=1836&jsn=1104
The larger bore moves more volume and offers less pressure.
My pedal travel was 'corrected', and the extra leg pressure I needed to use was minimal, so I think it could work on your truck no problem. And yes, it looks a lot better than the Ranger one !
If you decide to change the MC to an aluminum/plastic one, before bench bleeding, booster rod gap checking, fitting and bleeding, connect the two existing wires to the two outer pins in the reed valve, turn on the ignition, and the red light should come on.
The reed valve switch on the F150 did not work when I got it, so I went to an electronics shop and bought another 'little brown thing' as per the picture :
The black box slides out easily from underneath the MC.
For illustration, I used these for the connections :
https://www.autoelectricsupplies.co....t/1/category/2
https://www.autoelectricsupplies.co....t/2/category/2
And each time, the brakes felt the same as before, OK but not great.
I thought about it one day, and realized I'd never changed the CV, so I got a new one and swapped it in.
No change whatsoever.
After that, I simply assumed that a 1970's F series truck had sh$t brakes.
Anyway, a few years later, I decided to change the rear drums to discs, for two reasons, I was curious, and, I hated having to remove the drive shaft, bearings, and, and, and, to replace a leaking cylinder.
I decided to remove the CV prior to doing the rear disc conversion, although I can't remember why I decided to do that.
Around about this time I bought a flaring tool, the cost of which, was probably covered by the savings in not having to pay a shop to do things.
I bought it because I knew I was going to be making lots of connections and changes (like the MC), and I wanted the convenience of doing it all at my leisure in my own time.
Anyway, I fitted a new rear brake line, set the CV on a shelf, and went for a drive.
F$$k !!!
The braking was brilliant !!??
I returned home, took the CV off the shelf, and put it straight into the bin.
During the drive, I braked hard to see how bad the nose dive would be. Hah! What nose dive ?
In the attached diagram, you'll see a 'metering valve' on the left, and this is supposed to prevent nose dive.
Which reminds me, I shouldn't have mentioned it earlier seeing as you have disc/disc. Duh !
The proportioning valve is on the far right of the picture, and without the CV in place, I also expected rear wheel lock up under hard braking. Nope !
How do we know that those valves actually work, or if they need calibrating ? We don't.
I fitted a proportioning valve in the rear circuit when I converted to discs, but I've never had to use it. (I.E. the rears still get 100% unrestricted supply.)
If you do decide to remove the CV, I'd suggest waiting until you are driving around with it, then remove it, so that you can experience the before/after effect.
Then decide if you need a proportioning valve or not.
I used the following to connect the front MC input to the two front outputs :
https://www.summitracing.com/parts/EAR-972052ERL
Initially I used a T, but my OCD didn't agree with it, and I preferred the connector to be bolted into place.
I don't like the coiled tubes leaving the MC, so I got braided hoses made up.
One supplied the front connector just mentioned, and one connected to the rear line using this :
https://www.summitracing.com/parts/AAF-ALL50130
Which reminds me, all of my lines are 3/16'', but I think some rears are 1/4''.
I fitted this proportioning valve into the rear line :
https://www.summitracing.com/parts/wil-260-10922
I used something like these to secure the lines :
https://www.summitracing.com/parts/RSD-RSCLP27
And I certainly don't miss having to use this when bleeding the brakes :
https://www.summitracing.com/parts/CLP-PV-TOOL
There you go, some food for thought.
