Pressure Differential Wiring
Old Oct 7, 2021 | 06:01 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Not that is is any where near the help and info from 6 by 8, but maybe some help nonetheless. I have some of the diagrams always posted here.
https://www.ford-trucks.com/forums/1...l#post14696861
Old Oct 7, 2021 | 07:29 AM
dlburch's Avatar
dlburch
Notice in both versions of the wiring diagrams that the pin going to the pink/white wire is grounded when the key is in the crank position...
Testing procedures for the ignition switch call for continuity between the prove-out pin and the ignition switch body.
Voltage for the warning lamp is provided ONLY from the instrument cluster.
So in order for the prove-out circuit to illuminate the bulb, it's clear that electrically both pins are the same. You can prove this by checking continuity between the two pins on the valve.
Old Oct 9, 2021 | 03:27 AM
6 by 8's Avatar
6 by 8
Those are great diagrams, thank you Gentlemen.
I would never have associated ground wires with a 'live' ignition switch circuit, but it all makes sense now.
How do you upload a pdf so that it shows on the page, like yours, instead of showing as an attachment ?
I took a load of IQ Boosting tablets to work it out, but they either don't work, or I'm unfortunately immune to them.
I ran out of time in my last post, and didn't mention the tube nuts.
The M10 and M12 tube nuts in the 1995 Ranger MC require ''bubble'' flares on the lines.
The 9/16-18 and 7/16-24 tube nuts in the 2002 F150 MC require ''Double'' flares.
I bought these for my new combination valve (CV) :
https://www.summitracing.com/parts/SUM-220237
Before I threw the CV in the bin, I removed the tube nuts, and subsequently used them on my 2002 F150 MC.
The attachments show the differences between the flares, and which tube nuts are used on the CV.
File Type: pdf
Millam
Nov 11, 2017 12:30 PM
fontime
16
Mar 26, 2011 08:47 AM
79f150toy
Sep 14, 2007 03:52 PM
zebrastud57
Jun 7, 2006 10:40 AM
MyDads64
19
Dec 9, 2003 10:23 AM
