Y-Block Question
Old Oct 3, 2021 | 07:23 PM
Steve Harlow's Avatar
Steve Harlow
Y-Block Question
Quick question about Y blocks.
The thunderbird has shaft mounted rockers on it and is making a lifter tick, upon closer investigation the rocker arm on the foremost driver's side cylinder has a significant of lateral play, and appears to be the culprit.
(not my photo, but it's the leftmost rocker held back by that thrust spring/washer)
The other rockers appear fine. However the shop manual is of little help, and offers no course of adjustment. I'm assuming the washer spring has lost it's temper, but I'm not sure and wanted to ask more experienced hands what needs to be done.
Thanks.
Old Oct 3, 2021 | 08:26 PM
abe's Avatar
abe
I can't help you Steve but you might want to ask that same question on the Yblock forum. A lot of experts there.
Old Oct 3, 2021 | 11:54 PM
seaves46's Avatar
seaves46
I doubt that will be an issue , more likely the valve clearance needs to be checked .
Fords&Farmalls
27
Apr 11, 2022 09:26 PM
mulegal
25
Jan 20, 2020 01:51 PM
JT250
Sep 2, 2012 07:19 PM
71FoMoCo
Mar 1, 2010 12:16 PM
bigginsf250
Nov 1, 2004 10:05 AM
