Trailer Connected/Disconnected Issue
Old Sep 30, 2021 | 02:31 PM
Idahoagie's Avatar
Idahoagie
4th Gear
When I disconnect a trailer the next time I go somewhere the truck is still showing that last trailer as connected and continues to log miles for that trailer. Any idea what would cause this? I know the "Trailer Disconnected" feature works as I had to replace the umbilical plug on my trailer. There was a bent pin that was not maintaining contact. Fun when you are towing a 9,000lb trailer and it disconnects just as you come over a summit leading to a 6% downgrade.
Anyway, that problem has been corrected, but even before replacing the plug the truck would not sense when a trailer had been disconnected. I have tested all connections and both the truck and trailer plugs are wired correctly. All lights, brakes, charging line, etc. work fine to the trailer.
Old Sep 30, 2021 | 03:00 PM
senix's Avatar
senix
when disconnecting, you have to select no trailer in the options menu for towing, consult your owners manual.
Basically it is a memory function that has to then be selected as no trailer.
f350larry's Avatar
f350larry
Disconnect the trailer while the truck is running.
Old Sep 30, 2021 | 03:03 PM
senix's Avatar
senix
when disconnecting the trailer whether the truck is running or not, one still needs to go into the trailer settings and select "no trailer" for it to stop the accumulation of miles.
Old Sep 30, 2021 | 05:05 PM
Idahoagie's Avatar
Idahoagie
4th Gear
Doesn't make a lot of sense. I've had issues where the trailer umbilical has come disconnected and the truck senses it and posts a warning message immediately. So the logic is built in already. If you click on "OK" when the trailer disconnects the warning message goes away, but the truck still considers the trailer connected and clocks mileage. You may not have trailer lights or brakes though.
This seems illogical. If the truck can sense the trailer is disconnected, and I can select "OK" to acknowledge it, let me select something to indicate I know the trailer is disconnected and I'm okay with it.
And, IMHO, when I start the truck and there is no trailer connected, the truck should sense this and not assume the last trailer is still connected, even though it can't sense that trailer. That makes no logical sense (pun intended) at all.
Yes, I have found that if I disconnect when the truck is running the truck usually senses this and stops clocking trailer mileage. "Usually" but not always. Seems like there are some serious coding issues in this part of the Sync3 system.
Old Sep 30, 2021 | 05:46 PM
Alleydog's Avatar
Alleydog
Agree it doesn’t make sense but like Walter used to say “that’s the way it is”
Old Sep 30, 2021 | 06:40 PM
explorer003's Avatar
explorer003
With my 2022 F250- -I unplug my trailer with the engine running. Afterwards when I look through the "Towing" screen it shows "No Active" trailer.
Old Sep 30, 2021 | 07:57 PM
SasquatchNM's Avatar
SasquatchNM
I believe this is a software issue.
My 2015 F150 would sense the disconnected trailer and properly deactivate the towing status without additional input.
My 2020 F250 would sense the disconnected trailer, but I had to manually deactivate it through the display to stop mileage accumulation. I tried everything, including unplugging the trailer with the engine on, nothing helped.
My 2022 F250 works properly, no issues.
It's a software bug, you might ask your dealer to re-flash any towing related ECMs.
Old Sep 30, 2021 | 09:23 PM
edjunior's Avatar
edjunior
In my 2019, unplug while the truck is running. It does not continue to accumulate miles. If I forget, I just reconnect, make sure the truck is running, then disconnect. No issue. I don't know if it's the same for the '20 - '22's. But try it.
Old Oct 1, 2021 | 11:27 AM
Idahoagie's Avatar
Idahoagie
4th Gear
This makes sense. Gotta love that the functionality changes through the model years. I'd ask my dealer to re-flash the ECMs except that service call would cost me.
The functionality of this part of the system is an annoyance. I am aware of the methods available to let the truck know it is no longer connected to a trailer. It's just annoying that you have to do this. I don't normally tow with the trailer info screen displayed after the first 50 miles or so. Therefore that screen isn't displayed the next time I get in the truck, which could be a week later. So I don't think to turn it off.
Anyway, thanks for the answer regarding the ECMs. Next time I have the truck in for a mandated service I'll see if they'll also make some changes for me on the ECM.
Old Oct 1, 2021 | 06:41 PM
rklavoon's Avatar
rklavoon
They fixed this issue on the 2022 MY. You can disconnect with the truck running or not and the next time you start up it flashes trailer disconnected and the miles stop accumulating.
srkr
May 3, 2025 04:02 PM
CrossCut
2009 - 2014 F150
Feb 14, 2019 07:53 PM
bigwin56f100
15
Oct 9, 2017 01:58 PM
topgun2
2015 - 2020 F150
May 17, 2017 06:49 PM
gman97005
General Automotive Discussion
Feb 2, 2016 12:03 AM
