General Diesel Discussion
Leaks
Old Sep 28, 2021 | 08:36 AM
Kevin Heston's Avatar
Kevin Heston
Leaks
I have multiple trucks with the same problem. My 2000 F450 6 speed has a bad leak. When it rains i have to put a tarp over the windshield other wise I will end up with water on the floorboard and twice it bit me in the a**. A few years ago it backed into my other dump truck by itself cause the truck got wet. Then last year it backed into my '11 6.7. And my 2002 F250 will leak from the passenger handle really bad. The F450 has 250k the F250 has 303k. Do these trucks have a bad windshield or something?
Old Sep 28, 2021 | 03:52 PM
tjc transport's Avatar
tjc transport
i ain't rite
common problem with these trucks as they get older. pull the windshield and closely inspect for holes. repair as needed, and then use the special windshield primer before having the new glass installed.
Old Sep 28, 2021 | 05:01 PM
Kevin Heston
So I just replace the windshield then?
Old Sep 28, 2021 | 05:31 PM
tjc transport
i ain't rite
Nope, if you do not fix the holes and use the proper primer it will still leak.
Old Oct 5, 2021 | 04:25 AM
MoBill122's Avatar
MoBill122
Papa Smurf
If your windshield is 20 years old, I'd replace.... 20 years of nicks,scratches, etc.... windshields do get old & worn out.... you'll be amazed you can see again !
Depending on where ii is located, some leaks drip water onto computer, or fuse box, etc... You'll start having all sorts of weird things happening if that happens.
67merc
Jan 10, 2018 07:53 AM
coreyallan01
Nov 22, 2015 01:17 AM
antham
Nov 13, 2005 06:30 PM
Nightrain
Feb 13, 2005 09:05 AM
Big
Sep 14, 2003 05:15 AM
