Odd Long Cranking Issue
Old Sep 27, 2021 | 11:39 AM
jobimi's Avatar
jobimi
I'm having an issue on my '94 F150, 351. When I first go to start the truck in the morning, I have to crank it for what I'd say is a long time (4-5 seconds) before it starts. For the rest of the day it will start right up immediately. I just happened to figure out recently that if I go turn the key on, wait for the fuel pump to stop, then turn it back off, and then go to actually start it within an hour or so, it fires right up. I've also tried cycling the fuel pump two or three times and then trying to start, but that doesn't do the trick. Would you think fuel pressure regulator, fuel pump, or something else? Side note, I've replaced all vacuum lines, air charge sensor, water temp sensor (the one that actually talks to the computer), TPS, EGR valve, plugs, wires, cap, rotor, coil. I didn't do all that for this issue, but this issue has persisted through all of that. Also replaced leaking capacitors on the ECM.
Old Sep 27, 2021 | 12:30 PM
sandymane's Avatar
sandymane
Do the prime thing with the pump a few times and then pull the hose off the FPR and see if there is fuel in it or the strong smell of fuel.
Old Sep 27, 2021 | 12:48 PM
R&RFord's Avatar
R&RFord
It sounds like the fuel pressure is bleeding off overnight, but it should build back up very quickly when the pump comes on. You can put a gauge on it to see what is going on at the rail.
How old is the fuel filter?
Old Sep 27, 2021 | 03:00 PM
jobimi's Avatar
jobimi
The fuel filter was replaced about 2,000 miles ago (which translates to 2 years on this truck).
Old Sep 27, 2021 | 03:08 PM
rla2005's Avatar
rla2005
A fuel pressure test will tell you the full story here. Rent or buy one. Easy button.
Old Oct 16, 2021 | 06:01 PM
jobimi's Avatar
jobimi
Okay, ran a pressure test today. At first I thought I had gotten a bad gauge. I connected it, turned the key on, and no pressure reading. Zero. Yet, I could hear the pump and have been driving the truck, so obviously it's working. I finally just started the truck, and pressure built to 34 psi within a few seconds. Then tested with the regulator vac line off and plugged and 44 psi. Okay, we're right on the money on both counts when the truck is running. Shut the truck down, bled the gauge, turned the key back on, no pressure again. This time I decided to cycle the key several times. After about 3 cycles, I read around 20 psi. Side note, I was of the understanding that revving the engine should produce a pressure increase. I didn't see hardly any change when revving. Is that an issue? I'm also puzzled about something else. When I purged the gauge the first few times, I got VERY varnished fuel out (and the gauge was very clean and dry before I started. After the first few purges, fuel was nice and clean. Anybody have thoughts? I'm puzzled all the way around. Quick note too, no fuel leaking out of the vac line on the regulator.
Old Oct 18, 2021 | 07:39 AM
rla2005's Avatar
rla2005
You should get at leat 35 PSI on the first key cycle from Off to Run. Since you also observed very little pressure increase when blipping the throttle could be a weak fuel pump. Does the truck have two tanks?
Old Oct 18, 2021 | 08:04 AM
jobimi's Avatar
jobimi
It does have two tanks, but the rear pump has been dead since before I got the truck. So you're thinking weak pump even though I'm getting 44 psi with the engine running with the regulator unplugged?
Old Oct 18, 2021 | 08:10 AM
rla2005's Avatar
rla2005
Yes based on your previous statement "Side note, I was of the understanding that revving the engine should produce a pressure increase. I didn't see hardly any change when revving."
Under load, not idle, the pump may not be able to supply enough fuel. On the other hand the regulator may be holding things back. It is a simple and relatively cheap item to replace for testing purposes. I would do a FPR change before going into the fuel system. The 1990 and later gas engine F-Series trucks have a high pressure pump assembly in each tank. Each of these assemblies, Fuel Delivery Module (FDM), have a high pressure check valve and a shuttle valve to prevent flow into the unselected tank. These valves are known to leak which bleeds off fuel pressure to the unused tank. If the rear tank is getting mysteriously filled you have a bad valve in the rear tank.
It is an overly complicated system so that's why I suggest to start with the easy and less expensive parts first.
Old Oct 18, 2021 | 04:10 PM
jobimi's Avatar
jobimi
Ok. I'll check the rear tank first. I siphoned it down as close to empty as I could right after I got the truck, so if it has a significant amount of fuel in it, it will definitely indicate a problem. Any thoughts on the varnished fuel coming out of the rail during testing? It was probably the first couple of tablespoons and then clear. I would have thought the fuel rail would always be getting fresh fuel circulated? EDIT: Checked the rear tank. It's dry.
Old Oct 18, 2021 | 06:32 PM
rla2005's Avatar
rla2005
If the rear tank is dry you most likely have a weak front pump.
Old Nov 3, 2021 | 09:10 AM
jobimi's Avatar
jobimi
Ok, so after testing and observation, I really think the pump is fine, but the internal check valve has failed. 3 primes in the morning reliably starts the truck right up with no hesitation, and there's never any evident fuel starvation when driving. Did some poking around, and came up with what seems to be a direct fit Ford part that could solve this: Ford Check Valve If I have my info correct, this part was originally produced for a recall on '93 models to correct crossflow issues from one tank to the other, and would have been installed on the return line. Could I just turn it around and plug it into the output side of the fuel filter and accomplish my goal? Seems like a pretty easy solution unless I'm missing something.
Old Nov 3, 2021 | 09:22 AM
rla2005's Avatar
rla2005
I believe the return line is smaller than the supply line, 5/16 vs 3/8.
I have my doubts it would work for you.
ColterDC
Jan 20, 2017 01:26 PM
dpoc
18
Sep 25, 2011 08:39 PM
phillips91
1978 - 1996 Big Bronco
May 28, 2010 08:44 PM
kwade66
Jun 3, 2006 04:06 AM
Evicerate
Nov 12, 2003 05:09 PM
