28 Spline Ford 9" Question
Old Sep 26, 2021 | 07:25 PM
Luke56F100's Avatar
Luke56F100
I purchased a Truck and the Ford 9" does not belong to it. I want to change the oil in it so while I am at it I want to install new bearing, seals and races.
The tag on my Carrier says the following WES-AA 3.00 9
I have determined the following by various methods.
28 Spline Axel 3.00 Gears 4 1/2 " 1310 Yoke - Standard Support 3.219 x 1.125 Diameter Cap
I am trying to figure out what Wheel Bearings, Seals , Races and Lock Rings I need for these Axels from Timken?
Old Sep 26, 2021 | 09:44 PM
85e150's Avatar
85e150
Is it making noise? Changing all that stuff will require setting up the axle again. Have you ever done a setup?
Old Sep 27, 2021 | 07:16 AM
Luke56F100's Avatar
Luke56F100
I did a 31 spline axel several years ago and used Timken A20 Set 20 to do it but being a 28 Spline makes me unsure about the parts.
Old Sep 27, 2021 | 04:11 PM
85e150's Avatar
85e150
Sorry, you are looking for wheel bearing sizes, not the sizes in the carrier?
https://www.currieenterprises.com/9-...ends-explained
If it's a Mustang housing, those are thinner and not rated for heavy loads.
71mach351
Nov 2, 2014 08:21 PM
49willard
Oct 26, 2012 12:42 PM
wyckedcombo17
Apr 20, 2012 11:48 PM
48' fordster
May 5, 2010 12:49 PM
rockher_man
Apr 14, 2009 07:56 AM
