Column replacement
Old Sep 24, 2021 | 06:25 PM
sknarf1960's Avatar
sknarf1960
Column replacement
I have a 96 F250 powerstroke with a Manuel trans…….I understand a steering column out of a 93 F150 gasser with an automatic trans with work….thoughts ?? Thanks
Old Sep 24, 2021 | 06:33 PM
96 OBS's Avatar
96 OBS
I don’t think an auto trans column will work with a manual truck in any instance. Could be wrong tho. You’ll probably have to find a manual one
Old Sep 24, 2021 | 06:37 PM
sknarf1960's Avatar
sknarf1960
I’m not sure what it entails, but I was told I could remove the auto shift parts from it. But thanks again
Old Sep 24, 2021 | 06:39 PM
96 OBS's Avatar
96 OBS
I suppose it’s possible I’ve never actually tried. You might have a hole in it where the original shifter was. Again I’ve never actually tried
Old Sep 24, 2021 | 09:09 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
Most steering columns from 1992-1997 (even up through 04 with pickups and Crown Vics) will physically bolt into your pickup. Swapping some parts that are specific to your vehicle is possible including the column shroud covers, steering wheels, and button contact rings.
Old Sep 24, 2021 | 09:30 PM
96 OBS's Avatar
96 OBS
Good to know! Thanks for the correction
Old Sep 25, 2021 | 12:04 AM
Hit Man X's Avatar
Hit Man X
I shall leave this here...
Old Sep 25, 2021 | 12:08 AM
96 OBS's Avatar
96 OBS
Oh lord how long have you had that up your sleeve?
Old Sep 25, 2021 | 12:11 AM
Hit Man X's Avatar
Hit Man X
A fair bit of time.
Curious the differences between the columns. Take photos as you break them down please.
Hattjason
13
May 29, 2021 04:38 PM
big64
Apr 17, 2009 10:19 PM
tagreun
Feb 23, 2005 03:14 PM
