74 F250 steering column replacement
Old May 24, 2021 | 09:43 AM
Hattjason's Avatar
Hattjason
Looking for a replacement for the steering column in my 74 F250 supercab. Shift linkage broke and my mechanic said the whole column is bad. He doesn't deal much with classic vehicles and hasn't had any luck finding a replacement. Anyone know of a good source or if a later model column would be interchangeable? Thanks for any help/suggestions
Old May 24, 2021 | 04:38 PM
73 hi-boy 428 fe's Avatar
73 hi-boy 428 fe
Which column do you need?
Old May 24, 2021 | 06:46 PM
jakeharp's Avatar
jakeharp
Im in the process or rebuilding/re-installing my AT Column in my 76', not sure if your in the mood or wanna give it a go, but its doable, with some basic tools, a whole lotta patience and alcohol. The parts are 90% accessible with some limited exceptions, otherwise there are some aftermarket columns on the WEB but then you looking at some electrical work, if you just wanna get a new one and have your mechanic do it, i get it, there's some on Ebay and other sites guys have had luck with.
Old May 24, 2021 | 07:21 PM
Hattjason's Avatar
Hattjason
I'm not sure I understand. I'm not a mechanic of any sort. The shift linkage went out because the tube inside the column had rotted away. When my mechanic tried to fix ut he said the whole column was bad and needed to be replaced. It is anon tilt column for an automatic
Old May 24, 2021 | 07:26 PM
73 hi-boy 428 fe
Yea, didn’t know if it was an automatic or standard column. I have a automatic column I had in my 73 That is a good one. Only reason I am getting rid of it is do to putting in a tilt. Pm me if interested.
Old May 24, 2021 | 07:36 PM
Hattjason's Avatar
Hattjason
Apparently I can't pm because I'm a basic free membership
Old May 24, 2021 | 07:43 PM
73 hi-boy 428 fe
I didn’t even see you are a new member. Have to have so many posters first.
Old May 24, 2021 | 07:45 PM
73 hi-boy 428 fe
I got the email. I suggest you edit the post and remove it.
73 hi-boy 428 fe
Where are you located at?
Old May 26, 2021 | 03:49 PM
Hattjason's Avatar
Hattjason
I'm located in Salt Lake City Utah
Old May 28, 2021 | 08:24 AM
Hattjason's Avatar
Hattjason
I can't seen to find your reply from your email. Can you please email again? Text would also work if you're okay with that. 801-897-7410
Old May 29, 2021 | 04:48 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
2WD or 4WD? Manual or power steering? 1973/77 is the same, 1978/79 is different.
Old May 29, 2021 | 01:58 PM
Hattjason's Avatar
Hattjason
It is 2wd with power steering
Old May 29, 2021 | 04:38 PM
NumberDummy
When my mechanic tried to fix ut he said the whole column was bad and needed to be replaced. It is a non tilt column for an automatic.
The tube cannot "rot away." I suggest you find another mechanic, this guy is giving you a "song and dance" because he doesn't know how to repair it.
Replacing it with another used column: It may not be any better than what you have now, it might be worse.
There are nylon bushings on either end of the shift rod that attaches to the selector lever on the column, then to the transmission lever.
This bushing is available from Ford and is the usual cause for problems with a loose fitting shift rod, because they crack apart/disintegrate.
EOSZ-7341-B (replaced C8OZ-7341-A, C9TZ-7341-A & EOSZ-7341-A) .. Shift Rod Bushing - Upper & Lower are the same / Available from Ford
1969/96 F100/350 // 1973/96 Bronco // 1975/97 E100/350 // Misc 1968/90's Passenger Cars.
If you want to replace the shift tube...just because...
C9TZ-7212-E .. Shift Tube / Obsolete
1969/77 F100/250 2WD & F350 with A/T & P/S
CARPENTER NOS PARTS in Concord NC has 437 = 800-476-9653.
Mr08353
1997 - 2003 F150
Oct 18, 2017 08:26 PM
wrd0225
WTB - Parts & other
Jun 2, 2016 08:36 AM
zswiss182
Jan 25, 2010 01:48 AM
jlasater
Jan 23, 2002 09:21 AM
