Lights under gauges
Old Sep 22, 2021 | 10:12 PM
Cbibb's Avatar
Cbibb
Lights under gauges
Hey guys new here and hoping you can help. I tried searching and didn't find an answer to what I was looking for (may not have worded it correctly). But my dad passed away in June and left me his 1993 f150 extended cab long bed. The truck is nothing at all to look at but he loved this thing and had tons of money into it. New engine, trans, rear end, both fuel systems, exhaust etc.
But he had his own way of doing things that I didn't understand sometimes. He hated any kind of ce lights or anything that indicated a problem. So his answer was to cover everything up! I replaced the clear face for the gauges. But he has some red transparent tape over the lights under the gauge cluster on both sides and I'm trying to figure out what they are and what I need to return it to factory. It also doesn't have a gauge bezel (which I have also ordered). I took some pics and I'm hoping I can get them posted. Thanks for any help.
Old Sep 22, 2021 | 10:14 PM
Cbibb's Avatar
Cbibb
There is that red transparent tape in the same place on the other side but that pic didn't want to load. I believe the turn signals may be in there??
Old Sep 23, 2021 | 08:07 AM
jerryparks's Avatar
jerryparks
Lights, from left to right
Left turn signal, "Fuel Reset", Battery/Charge 4x4 Low, 4x4, Right turn signal
Old Sep 23, 2021 | 08:10 AM
jerryparks's Avatar
jerryparks
Alternatively, your truck may be equipped with factory airbags or anti-theft, in which case its
Left turn signal, Theft, Airbag, 4x4 Low, 4x4, Right turn signal
The first one i posted is only applicable to some 1992 & 1993 trucks. All trucks after 1994 and some 1992 & 1993 trucks are equipped with this layout
Old Sep 23, 2021 | 08:34 AM
Cbibb's Avatar
Cbibb
Thank you very much. Is there some sort of cover that I can put over these to see what is lighting up? Or will the dash bezel have that? From your description the battery light was on when I got the truck and it always started very slowly. I noticed that the voltage regulator wire was very loose barely making contact on the alternator. Fixed that and the light is off now. Appreciate the help!
Old Sep 23, 2021 | 08:49 AM
jerryparks's Avatar
jerryparks
This is a link to LMC truck. I don't know where you purchased yours from, but it should come with those covers.
If your truck doesn't have airbags, then yes, that light would probably be the battery light and loose wires on the voltage regulator would cause that.
Instrument Bezel (lmctruck.com)
Old Sep 23, 2021 | 08:52 AM
Cbibb's Avatar
Cbibb
Thanks again very much! Sure do appreciate it!
Old Sep 23, 2021 | 09:40 AM
rla2005's Avatar
rla2005
1993 F-Series/Bronco Base Instrument Cluster (No Airbags in 1993)
crp461
Aug 5, 2019 09:53 AM
creich68
Apr 1, 2012 02:18 AM
1975StroppeBaja
Mar 1, 2009 06:55 AM
Fire Rooster
May 6, 2005 10:21 PM
smitty7
General Automotive Discussion
Apr 16, 2004 05:48 PM
