M5od help sought
Old Sep 22, 2021 | 05:15 PM
Wolfpack1983's Avatar
Wolfpack1983
M5od help sought
Just want to say thanks in advance for all the help this forum has provided. I have used this forum as a resource for years and have always found the answer to any issue by simply searching old threads. The issue I have now I wasn't able to solve, so, first post seeking help.
I have a 1995 F-150 5.0 with the m5od transmission. Last weekend I pulled off the top cover to replace the gasket (had a few drops under the truck and knew I had never replaced the gasket. Did the freeze plugs when I first got it.)
I took the top cover off with the shifter in neutral and replaced the gaskets and put it back on. Also added sound deadening throughout the truck while I was in there. After I finished the sound deadening and got the truck all back together I hopped in to go for my test drive and the truck will not move.
I can shift through all of the gears, no excessive movement, like the shifter hitting the radio. Not hard to get into any of the gears either, feels just like before. When I go to release the clutch theres just no engagement, feels like its in gear but truck just sits there. Clutch pedal feels the same as before, good tension on it with a little travel at the top.
Sorry for the long post, but any help would be greatly appreciated.
Old Sep 22, 2021 | 06:59 PM
Mudsport96's Avatar
Mudsport96
Something isnt lined up correctly. Best bet is pull the top cover and double check
Old Sep 22, 2021 | 09:47 PM
Mudsport96's Avatar
Mudsport96
Also, if it is four wheel drive... make sure you didnt knock the transfer case into neutral.
Old Sep 23, 2021 | 12:29 PM
Wolfpack1983
Pretty embarrassed to say thats exactly what I did... in my rush to test drive it, I threw it in neutral, not 2H. It got knocked out of 2H when I was taking the boot off to put the sound deadening on the floor.
Thanks so much for the help!!!
Old Sep 23, 2021 | 08:20 PM
Mudsport96's Avatar
Mudsport96
welcome. Done it myself, that's why i suggested it.
robs01f250
Dec 6, 2010 07:23 PM
Ezee4U2C
Jul 23, 2008 09:15 PM
ChaoticBaz
Apr 26, 2007 09:22 AM
Biwanylo
1983 - 2012 Ranger & B-Series
Jan 24, 2006 10:38 PM
JamieD
Jun 25, 2003 06:37 PM
