LiFePO4 for main battery
Old Sep 22, 2021 | 10:10 AM
blaczero's Avatar
blaczero
Anyone using this as the starter battery? I have a compressor on board and want to use it a lot with engine of, figured it be useful to use a lithium battery instead of flooded.
Old Sep 22, 2021 | 10:18 AM
smikesF350's Avatar
smikesF350
I was thinking of using those batteries in my motorhome and have heard that these type of batteries require a completely different charging system and that the normal alternator destroy the battery.
Old Sep 22, 2021 | 10:34 AM
seventyseven250's Avatar
seventyseven250
I think "standard best practice" would be to run a second battery that was responsible for the accessory load, and have an isolator between them so you can't run the main starter battery down.
Old Sep 22, 2021 | 11:28 AM
scraprat's Avatar
scraprat
Top Answer: 5
Lifepo4 will not like the heat of the engine compartment of a vehicle.
Old Sep 22, 2021 | 12:52 PM
BillyE's Avatar
BillyE
Originally Posted by scraprat;[url=tel:20075598
20075598[/url]]Lifepo4 will not like the heat of the engine compartment of a vehicle.
Nor do they supply the necessary CA. These are deep cycle batteries.
Old Sep 22, 2021 | 12:55 PM
GM in a Ford's Avatar
GM in a Ford
They don't like cold either. Can't charge them below around 30 degrees.
Old Sep 22, 2021 | 01:19 PM
scraprat's Avatar
scraprat
Top Answer: 5
I wouldn't know much about them.
Old Sep 22, 2021 | 04:15 PM
Christopher McCarthy's Avatar
Why not just go with an AGM?
Old Sep 23, 2021 | 07:47 AM
B-ManFX4's Avatar
B-ManFX4
AGM is a battery construction strategy, not a battery chemistry. Its fundamental chemistry is still based on lead, sulfuric acid and water. LiFePO4 is a totally different battery chemistry and not really suited to vehicle starting applications.
Old Sep 24, 2021 | 08:17 AM
MAX4utah's Avatar
MAX4utah
I have one on my boat and love it. For a vehicle though, the comments above are accurate. Most Lithium cases will start to swell above 140*F.
SBV45
2009 - 2014 F150
Jan 6, 2022 06:36 PM
TCMATHEWS
Jan 8, 2014 11:29 PM
Greywolf
General Automotive Discussion
Aug 22, 2010 07:16 AM
jimbo beam
Electrical Systems/Wiring
16
Dec 31, 2006 07:35 AM
slifer
May 16, 2004 04:44 PM
