1978 - 1996 Big Bronco
Help Decode Diff Tags
Old Nov 2, 2003 | 03:38 PM
rlh's Avatar
rlh
I bought a 1990 Bronco XLT (302 AOD) but am not sure about the differentials.
Rear has 2 lines of numbers:
Top line: S844A
Bottom line: 3 53 88 9H30
Front has 2 lines
Top: 3 54 (upside down triangle) EDE8TA SC
bottom: (upside down triangle) 61010-2
I assume the rear is a 3.55 open and the front is a
Dana 44 open 3.54 which is what the door plate says but these could have been changed/modified.
The tag on the Borg-Warner Transfer case
Top Line: H269 3 1356-38
Bottom Line: 107251 E9TA-MB
Thanks in advance, rlh
Old Nov 2, 2003 | 04:15 PM
89BroncoResto's Avatar
89BroncoResto
The rear diff is a 8.8 inch open diff with 3.55 gears. The front is a Dana 44, 3.54 gears. I don't know about the t-case, other than its a Borg Warner 1356. Hope this helps!
Old Nov 3, 2003 | 10:54 AM
rlh's Avatar
rlh
Thanks! I know thats what is supposed to be there but I wanted to check the tags to make sure they were original but wasn't sure if I interpreted the correctly.
David Greenhalgh
13
Jan 7, 2016 04:54 PM
ScottInTexas
Dec 27, 2015 10:41 AM
ScottInTexas
Jun 11, 2015 04:12 PM
F250Rob
Jan 5, 2011 04:30 PM
Shawn63200
Mar 12, 2010 02:20 PM
