hi evryone ,
hope all doing well , i did quite some research and couldnt find any specific info , i have a 2015 f150 xl without keyless entry , i installed a remote start ,keyless entry and i am having hard time to find where to connect lock and unlock trigger , i though to the switch of the door pannel ,but those switches does not work too , which wires should i be looking to? BCM module wiring seems complex and hard to understand which wire will trigger lock and unlock
none of them in my area understand fords , and id rather not let someone chop my car for quick bucks as they normally dont care which wire they splices as long as it works .any other suggestions?
No car audio shop in your area understand “Fords” and they don’t care which wire they splice into?
If you say so.
There’s nothing special about the 12 volt system on a Ford compared to any other make.
