Sponsored by: Real Truck
cp4 bypass issue
Old Sep 21, 2021 | 12:05 PM
JJaetzold's Avatar
JJaetzold
cp4 bypass issue
First post...
2014 F250 Deleted and tuned, Has been running great for 60K miles on tune. Decided to have cp4 bypass installed. The Mechanic used XDP kit. After install truck runs fine as long as you baby it. Stomp it and it throws P0087 low pressure at rail. Changed the filters, and also change the low pressure pump on the frame. Same result. Any suggestions?
Old Sep 21, 2021 | 01:26 PM
Desert Don's Avatar
Desert Don
Originally Posted by JJaetzold
First post...
I would do it the EZ way………go back to the guy that did the install. Let him finish what he got paid for.
Old Sep 21, 2021 | 06:27 PM
JJaetzold's Avatar
JJaetzold
that’s what I did today.
Last edited by Y2KW57; Sep 21, 2021 at 11:03 PM. Reason: corrected anomalous vb code error that software filter interpreted as spam, then approved post
Old Sep 25, 2021 | 03:59 PM
speakerfritz's Avatar
speakerfritz
Check the oil ring under the actual bypass manifold
the large one in the middle sometimes does not go in correctly and results in air being sucked in.
the oring with the star plastic holder does not have air being sucked in problems.
gem930
Mar 18, 2021 11:29 AM
Work Truck Fanatic
Nov 22, 2020 03:50 PM
crrider999
6.4L Power Stroke Diesel
Nov 28, 2016 08:30 AM
EPNCSU2006
19
Dec 19, 2003 03:57 PM
