Break In 6.7?
Old Sep 20, 2021 | 10:14 AM
Tsubakihara's Avatar
Tsubakihara
Originally Posted by cat-alac
I believe the manual says 7500-11000 miles. I did mine at 10,000 was under the impression that the factory oil has break in additives that are required to min 7500 miles.
That's a long way in a fully smog burdened modern diesel without bypass filtration.
Old Sep 20, 2021 | 10:22 AM
4wd6.7L's Avatar
4wd6.7L
The manual says to change it when the oil life monitor says so, it also includes some examples of when that might be. That 7500-10k might be what they say you can expect from normal use, I personally think that is too long. They also say not to exceed 1 year or 10k miles.
If they included language saying that there is in fact break in oil that should be left in for x amount of time that would be one thing, but being that it's uncertain I chose to do an early first change.
Old Sep 20, 2021 | 11:06 AM
Doug Savage's Avatar
Doug Savage
Hmmmm…. We’ll then that’s the key for me. Is there or isn’t there a special oil additive from Ford at delivery???
Old Sep 20, 2021 | 11:33 AM
C12H24's Avatar
C12H24
No. And this notion of the factory using a break in oil is myth. And no additives of any kind. There was a time, decades ago, where detergent oils were not recommended for engine run in and the break in period. But there was nothing special about a non-detergent oil. You can still buy it today. It's mostly used for lawn mowers and non-combustion applications, like air compressors. It's principle advantage is that most everything in the bottle is oil, and not the additives used to make it multi-grade, detergent and so on. And engine break in occurs in very short order, like by the time you get the truck home from the lot. The days of taking 5,000 miles to seat chrome-faced rings were pretty much over in the '60s. You do get some incidental metals shed into the oil that some refer to as break in metals, but those are very modest amounts. The filter will generally catch most of that. It's very inconsequential.
Old Sep 20, 2021 | 11:41 AM
shawnee1's Avatar
shawnee1
Originally Posted by willynilly
let me remind you that the people writing your service book are the same people that gave you axles with tubes that crush, death wobble, tail gates that unexpectedly open on their own, fuel filters that catch engine bays on fire along with a host of other racalls and tsb. if the vehicle gets through the warranty period , even just barely ,thats what they care about. besides that, maintaining a vehicle includes alot more than just engine oil changes. alot of people will never once get under the vehicle and check for leaks or worn parts or take any other preventive maintenance steps.
its not just a jab at ford. other vehicle manufacterers are no better about the maintenance intervals. do you think the brilliant engineers care one bit if that vehicle is still in good running order at 200k or 300k. hell no they dont care. owners have to take matters into their own hands
First, they are not the same people. There are numerous design teams that work independently on the particular systems they are responsible for.
Second, even I don't care if the truck is in good running order at 200k or 300k. I think the majority of first owners will never get past 100k. Furthermore, I don't think doing the initial oil change at 1k or 2k will make a meaningful difference in the engine going for 200k miles. There are too many other factors involved.
Of course, this is just my opinion.
Old Sep 20, 2021 | 11:51 AM
zeroo's Avatar
zeroo
I do first oil changes early in trucks and equipment but then stick to manufacturer recommendations. Like my truck I wait til about 10% remaining and fuel filters every 30k.
Old Sep 20, 2021 | 12:20 PM
BillyE's Avatar
BillyE
If changing the oil makes you feel better about any of these items, then go for it.
Old Sep 20, 2021 | 05:51 PM
zmetalmilitia's Avatar
zmetalmilitia
They are also the same people that designed and built the 6.7 PS so there is that
Old Sep 20, 2021 | 09:02 PM
TCNashville's Avatar
TCNashville
DIY oil changes are still fairly inexpensive so the bottom line is do whatever makes you feel better with regards to you and your truck. It's win -win all the way around.
CollinsCD
Aug 19, 2015 09:17 AM
RollingRock
Jan 20, 2011 04:40 PM
UGA33
2009 - 2014 F150
Nov 17, 2009 10:26 AM
dannyo
Mar 27, 2006 09:07 PM
mrc59
May 25, 2004 09:20 PM
