How often do you change 'em?
Old Mar 26, 2006 | 12:24 AM
dannyo's Avatar
dannyo
Fuel filters.
Thanks,
Danny
Old Mar 26, 2006 | 12:27 AM
Bird Dog's Avatar
Bird Dog
Originally Posted by dannyo
Fuel filters.
Thanks,
Danny
Every other oil change for me.
Old Mar 26, 2006 | 12:40 AM
SpringerPop's Avatar
SpringerPop
Since I added the Dahl, I haven't.
Pop
Old Mar 26, 2006 | 01:06 AM
chapguy's Avatar
chapguy
I check it every oil change and if it's nasty I change it. Otherwise I change every other oil change. Once I started running biodiesel I had to change it a couple of times but I think most of the crud is out of the fuel system now so it's back to every other oil change which is 10K miles.
Old Mar 26, 2006 | 07:30 PM
jtharvey's Avatar
jtharvey
Before the Dahl, it was every 7500 miles. Probably overkill, but I like to play it safe. But, like Pop said, after the Dahl, I probably won't need to change it, but will do so probably once a year, 15,000 miles or so.
Old Mar 26, 2006 | 07:38 PM
CAT_man_963's Avatar
CAT_man_963
I change mine every 10,000 miles or so - and I have yet for it to even look at all dirty!! Hope to be getting a pre-pump filter set-up soon though.
Old Mar 26, 2006 | 08:20 PM
Lushman's Avatar
Lushman
So it begs to ask the next question, how often do you change the Dahl filter?
Old Mar 26, 2006 | 08:23 PM
SpringerPop
When the power starts to drop off noticibly.
I suppose I could put a vacuum gauge on it, but the reading varies with flow, so I'd have to mount it in the cab somewhere I could see it while at speed. So, I ainna' gonna' do it.
Seat of the pants "feel" gets it changed.
Seriously, if I were going to change it on a time/milage schedule, it would likely be something like every year/15,000 miles. But I can't see doing it that way, as I can use a LOT of fuel from OTR fuel stops, all of which is pretty clean, or I can some drinkwater back-woods crud that clogs it in a single tank.
So I change it when it's needed. They call that "on-condition".
Pop
Old Mar 26, 2006 | 08:38 PM
Muktown's Avatar
Muktown
every 10,000
Old Mar 27, 2006 | 12:45 PM
hott-rodd's Avatar
hott-rodd
When my pre-pump filter gets dirty my truck make more noise like a cold diesel in the morning. I'm still running the cheap see thru auto filters because i like to see whats going on in there. Extra $3-4 every oil change ~5k miles.
Old Mar 27, 2006 | 12:50 PM
jonmacs22's Avatar
jonmacs22
how easy is it to change?
instructions available online anywhere?
Old Mar 27, 2006 | 01:31 PM
72Lester's Avatar
72Lester
Once a year
Every September (usually 10-12K). I make sure they are good for the winter. Never had a gel-up and don't want one either. I do only buy diesel from commercial trucking centers though. If I bought at the smaller mom & pop stations I'd probably change 'em a bit more often...less chance of dirty or watery fuel or settling issues at the high fuel turnover places.
Old Mar 27, 2006 | 09:07 PM
sawfish99's Avatar
sawfish99
Every oil change. I went about 10k the first time after I got the truck and it was nasty, black, and looked clogged. Every one I have pulled out since has been a little less dirty. I figure a filter is cheaper than engine problems - even if it is ok a little longer.
