Bed Realignment
Old Sep 19, 2021 | 03:56 PM
Captain 40's Avatar
Captain 40
Bed Realignment
Curious if any of you have realigned your bed and if it is very difficult to do. I have the 8 ft bed. Specifically what I'd like to do is shift the bed towards the passenger side about 3/8 inch at the back end to get better tire/axle to bed alignment (which is off). Is it possible to move it that much? Is it just a matter of removing the bolts and shifting/sliding the bed to one side, then reinstalling new bolts? I see there are a couple of plastic alignment pegs next to the front bolts, are they present at the other bolt locations? Any other considerations?
Thanks in advance for any helpful information.
C-40
Old Sep 19, 2021 | 06:09 PM
T. Banning's Avatar
T. Banning
C-40
If there are no pins in the rear, you should be able to do as you talking about. I wouldn't worry about new bolts, but that's my opinion.
Old Sep 20, 2021 | 10:36 AM
Tsubakihara's Avatar
Tsubakihara
C-40
We took my sons bed off - get the socket, take bolts out, lift off, back on the pins, wiggle wiggle, tighten and done. It's harder to change some spark plugs.
Old Sep 20, 2021 | 03:45 PM
Captain 40's Avatar
Captain 40
Were there plastic alignment pins at each bolt location? I was hoping just to remove bolts and slide the bed slightly and not lift, if possible. Thanks.
Old Sep 20, 2021 | 03:55 PM
4wd6.7L's Avatar
4wd6.7L
I don't recall, but I'm thinking there are 4 plastic pin locations. If you are only trying slide it a little I wouldn't remove the bolts, just loosen them and see what you can get.
Old Sep 20, 2021 | 04:09 PM
Norcalpr's Avatar
Norcalpr
Plastic pins are only on the pass side, front and back of the bed. I did a post about adding a fifth wheel hitch. Look atthe posts I've started in my profile, the pics are in that thread and you can probably see um.
If you want to align the bed you'll have to remove those pins. There's not much wiggle room with them in
Old Sep 20, 2021 | 05:23 PM
Captain 40's Avatar
Captain 40
Thanks for the info y'all. Very helpful. Now I just have to figure out how I will slide it sideways once I get the bolts loosened up and pins removed.
Old Sep 20, 2021 | 05:44 PM
HorizontalHunter's Avatar
HorizontalHunter
Why is your bed out of alignment?
If there is little wiggle room as @Norcalpr posted you might have a bent frame or the rear axle may have shifted.
Bob
Old Sep 20, 2021 | 05:47 PM
Chris 86's Avatar
Chris 86
Bob
It seems pretty common. Mine is off by about 1/2". You can tell looking at the mud flaps in relation to the tires.
Old Sep 20, 2021 | 05:55 PM
HorizontalHunter
WOW That’s pretty **** poor QC.
Bob
Old Sep 20, 2021 | 07:30 PM
Norcalpr's Avatar
Norcalpr
Push on it? The bed isn't heavy at all, and you could lift if off if you have about 4 or 6 people... the holes are all larger than the bolts so there's a lot of room to move it once everything is loose and the pins are gone.
Old Sep 20, 2021 | 09:18 PM
Tsubakihara
Sorry, should have been more clear. Loosen bolts and there is adjustment available. No need to lift.
Old Sep 20, 2021 | 11:30 PM
Sonny Crockett's Avatar
Sonny Crockett
My 17' is off too. Dealer said it's within the margin of error and won't align.
avf100
26
Jun 21, 2021 11:01 AM
KWDAILYD
Feb 15, 2018 10:00 AM
BIG66PROJECT
Apr 23, 2006 11:40 PM
deaddux
Paint & Bodywork
Oct 13, 2005 07:37 AM
CrewCheifV10
Jun 30, 2003 10:07 AM
