Quick question
Old Sep 19, 2021 | 11:59 AM
Listor's Avatar
Listor
Quick question
I think i did not put enough grease in my front hub, can i just lube it through the abs port, or should i remove and regrease?
Old Sep 19, 2021 | 01:21 PM
BWST's Avatar
BWST
Got Data?
For the unit bearings, you can lube them through the ABS port.
For the needle bearings that carry the stub shaft, that generally has to be lubed by removing the hub - but...
Y2K has a method in the Tech folder to grease those bearings while still mounted.
https://www.ford-trucks.com/forums/1...l#post16961300
FTN has suggested you can lube them through the vacuum port, if you have manual lock hubs (not using the stock vacuum lock hubs). I want to try this once I get the right sized zerk fittings.
Old Sep 19, 2021 | 06:02 PM
Listor's Avatar
Listor
Thanks I pulled it to lube the needle bearings I might buy one of riffraffs grease zeros for the main bearing thought
Old Sep 20, 2021 | 09:09 AM
Listor's Avatar
Listor
Just for the record i am getting pretty fast at pulling the hubs LOL
MattyP10178
Dec 5, 2016 11:45 AM
TKegs763
Sep 25, 2013 07:45 PM
anothersteveg
May 5, 2009 02:54 AM
molotov
Jan 23, 2008 09:27 PM
mongo75
Jan 12, 2007 04:54 AM
