View Poll Results: I have a 2003 E350 fuel pump quit this summer
Sensor controls pump
0%
Bad pump
100.00%
Bad sensor
0%
Started working as weather cooled down
0%
Multiple Choice Poll. Voters: 4. You may not vote on this poll
2003 e350
Old Sep 17, 2021 | 03:46 PM
Idahophil969's Avatar
Idahophil969
1st Gear
2003 e350
My fuel quit this summer but as the temperatures got cooler it worked the other day is there a sensor that controls the pump or is it a bad pump hate to drop the tank if I don't have to!
Old Sep 17, 2021 | 03:54 PM
85e150's Avatar
85e150
Welcome to FTE.
Moved to the Van forum.
What engine do you have?
It sounds like your fuel pump quit when it was hot, right? It might work now that things are cooler but the safe bet would be that it will quit again for you.
Old Sep 19, 2021 | 03:46 PM
econo93's Avatar
econo93
My '93 with 5.8 was doing the same thing last year when the weather was hot. It happened a couple of times in warmer weather but would start back up after cooling down but finally I had to have it towed. Thankfully, it was local. It was acting like a vapor locked truck with a carb.
This link may help in understanding what's going on:
https://www.onallcylinders.com/2016/...-you-avoid-it/
I didn't want to drop the tank (midship,35gall.) so I cut a hole in the floor for access. Luckily there were a couple of online tips on doing this and from the pics I could tell just where to cut. I didn't bookmark those though, so you'll need to do a search. I did save a couple of pics:
E150 Fuel pump access
frankies31
6.4L Power Stroke Diesel
26
Jul 24, 2022 08:47 AM
Fordtruckowner87
Nov 11, 2018 09:36 PM
gman97005
Jan 29, 2015 08:49 PM
80s Trucker
Jan 20, 2015 12:53 AM
robs68
Jul 31, 2000 04:12 PM
