I just switched from 2in drop coils to the 3inch drop beams. I put the old coils back in, but after everything’s buttoned up it sits the same if not a little higher than with the drop coils.
I went back and checked and I had replaced the factory coils with Moog 822s, which then went in with the beams. Is that why it might be sitting higher? Would 820’s get it where it should be? (Stock coils are long gone)
perhaps drive it and it will settle. If I jack up the corner of the car it will come to rest higher and take a while to just settle the previous height. Get some use like any and it shouldn’t settle to be accurate
