Mass Air Flow Sensor
Old Sep 11, 2021 | 05:41 PM
RedneckoftheNorth's Avatar
RedneckoftheNorth
5th Gear
I have a 86 f250 and I don't want to have to replace the MAF sensor everytime it acts up just so it will idle down. I just unplugged the sensor and the truck runs better now but will there be any repercussions if I leave it like that.
Old Sep 11, 2021 | 05:58 PM
Conanski's Avatar
Conanski
You mean a '96 I'm sure.
What problem are you having?
Have you pulled codes to see if anything is flagged
Old Sep 11, 2021 | 08:13 PM
RedneckoftheNorth
5th Gear
No it is a 86, it was the first year ford made electronic fuel injected engines. But it was always idling at around 800 rpm instead of like 650 or 700 so I just unplugged the mafs and it idled down to the right rpm.
Old Sep 11, 2021 | 10:21 PM
Conanski's Avatar
Conanski
A first year EFI truck did not have MAF, so if yours does it has been converted. Either way unplugging it is not a good thing to do, something is giving the computer bad info and you need to figure out what that is... which is where pulling codes come in. Prime suspect is a bad TPS but there could be other causes too.
cnvF250
2009 - 2014 F150
Feb 3, 2015 09:44 AM
njtinman2
Oct 16, 2014 09:58 AM
rsulvan
Mar 24, 2007 09:36 AM
anschutz1913_ss
Mar 31, 2006 06:35 PM
dgodude
Sep 3, 2002 07:24 AM
